hello,
i use a pico gateway néméus and with this one with my configuration, i have this log:
chirpstack-network-server[686]: time=“2020-05-20T08:43:43+02:00” level=error msg=“finished unary call with code Unknown” ctx_id=a33b4e38-5edd-42a6-a407-f061f88b9a5b error=“rpc error: code = Unknown desc = lorawan/band: invalid data-rate” grpc.code=Unknown grpc.method=SendProprietaryPayload grpc.service=ns.NetworkServerService grpc.start_time=“2020-05-20T08:43:43+02:00” grpc.time_ms=0.377 peer.address=“127.0.0.1:44446” span.kind=server system=grpc
mai 20 08:47:51 btssn-VirtualBox chirpstack-application-server[701]: time=“2020-05-20T08:47:51+02:00” level=error msg=“finished client unary call” ctx_id="" error=“rpc error: code = Unknown desc = lorawan/band: invalid data-rate” grpc.code=Unknown grpc.ctx_id=a8edae23-9115-4383-92d7-987f665ce2ec grpc.duration=1.499259ms grpc.method=SendProprietaryPayload grpc.service=ns.NetworkServerService span.kind=client system=grpc
mai 20 08:47:51 btssn-VirtualBox chirpstack-application-server[701]: time=“2020-05-20T08:47:51+02:00” level=error msg=“send gateway ping error: send ping error: send proprietary payload error: rpc error: code = Unknown desc = lorawan/band: invalid data-rate”
Pico gateway Néméus work in Chirpstack?
in Device Profile i use “Device supports otaa”
I check Device Support Class-B et C
thank you in advance.
Michel
