I’ve deployed the chirpstack services + postgres with docker compose. The containers don’t have any problems when they have to connect to other containers like mosquitto. I’m trying to add the postgres integration, so I edited its toml file:
enabled=["mqtt", "postgresql"]
[postgresql]
dsn="postgres://chirpstack_as:chirpstack_as@postgresql/chirpstack_as?sslmode=disable"
I’ve also exposed the port in the docker-compose file:
version: "3"
services:
chirpstack-network-server:
image: chirpstack/chirpstack-network-server:3
volumes:
- ./configuration/chirpstack-network-server:/etc/chirpstack-network-server
chirpstack-application-server:
image: chirpstack/chirpstack-application-server:3
ports:
- 8081:8080
volumes:
- ./configuration/chirpstack-application-server:/etc/chirpstack-application-server
chirpstack-gateway-bridge:
image: chirpstack/chirpstack-gateway-bridge:3
ports:
- 1700:1700/udp
volumes:
chirpstack-geolocation-server:
image: chirpstack/chirpstack-geolocation-server:3
volumes:
- ./configuration/chirpstack-geolocation-server:/etc/chirpstack-geolocation-server
postgresql:
image: postgres:9.6-alpine
ports:
- 5432:5432
environment:
- POSTGRES_PASSWORD=root
volumes:
redis:
image: redis:5-alpine
volumes:
- redisdata:/data
mosquitto:
image: eclipse-mosquitto
ports:
- 1883:1883
volumes:
- ./configuration/mosquitto:/mosquitto/config/
- ./configuration/mosquitto/logs:/var/log/mosquitto
volumes:
postgresqldata:
redisdata:
However the chirpstack application doesn’t seem to connect with the postgres container. From its logs:
time="2021-11-30T11:05:30.238296643Z" level=info msg="starting ChirpStack Application Server" docs="https://www.chirpstack.io/" version=
time="2021-11-30T11:05:30.238396612Z" level=info msg="storage: setting up storage package"
time="2021-11-30T11:05:30.238428593Z" level=info msg="storage: setup metrics"
time="2021-11-30T11:05:30.238479373Z" level=info msg="storage: setting up Redis client"
time="2021-11-30T11:05:30.238628981Z" level=info msg="storage: connecting to PostgreSQL database"
time="2021-11-30T11:05:30.272370748Z" level=info msg="storage: applying PostgreSQL data migrations"
time="2021-11-30T11:05:30.301162017Z" level=info msg="integration: configuring global integrations"
time="2021-11-30T11:05:30.301741884Z" level=info msg="integration/mqtt: TLS config is empty"
time="2021-11-30T11:05:30.301789365Z" level=info msg="integration/mqtt: connecting to mqtt broker" server="tcp://mosquitto:1883"
time="2021-11-30T11:05:30.304668978Z" level=info msg="integration/postgresql: connecting to PostgreSQL database"
time="2021-11-30T11:05:30.304760821Z" level=info msg="integration/mqtt: connected to mqtt broker"
time="2021-11-30T11:05:30.304926557Z" level=info msg="integration/mqtt: subscribing to tx topic" qos=0 topic=application/+/device/+/command/down
time="2021-11-30T11:05:30.306507168Z" level=warning msg="integration/postgresql: ping PostgreSQL database error, will retry in 2s" error="dial tcp 127.0.0.1:5432: connect: connection refused"
time="2021-11-30T11:05:32.308815371Z" level=warning msg="integration/postgresql: ping PostgreSQL database error, will retry in 2s" error="dial tcp 127.0.0.1:5432: connect: connection refused"
And goes on with the connection refused message. It seems it’s trying to connect to a local instance rather than the one defined in the toml.
I’ve tested the postgres container and I can:
- connect to the database from the local machine
- connect to the database from a remote machine
- connect to the database from another container, I’ve used jbergknoff/postgresql-client with the same dns string.
All with the same username / password / database.
