I have a question about the installation of the OS gateway, I would like to know how to verify if the antenna is booting and what is the approximate installation timeout with a basic micro sd?
Did You learn this resources ?
https://iot.wifx.net/docs/download-area/operating-system-images
https://www.lorixone.io/wiki/NAND_Programming
The lorix one is factory installed, I need to install the ChirpStack Gateway OS
Try to connect GW via serial console.
