I was interested by chirpstack simulator tool. I have tried to set it up .
I have done configuration according to my setup
When i lauch it seems there is no error but nothing appen …
is there logs somewhere to understand what happen ?
user1@cl3vm1130:~/chirpstack-simulator/chirpstack-simulator-master$ ./build/chirpstack-simulator -c chirpstack-simulator.toml
INFO[0000] starting ChirpStack Simulator docs=“https://www.chirpstack.io/” version=
INFO[0000] as: connecting api client insecure=true server=“10.35.97.101:8080”
INFO[0000] as: connecting to mqtt broker server=“tcp://10.35.97.101:1883”
INFO[0000] ns: connecting to mqtt broker server=“tcp://10.35.97.101:1883”
INFO[0000] starting Prometheus endpoint server bind=“0.0.0.0:9000”
Below the configuration file i m using
$ cat chirpstack-simulator.toml
[general]
Log level
debug=5, info=4, warning=3, error=2, fatal=1, panic=0
log_level=4
Application Server configuration.
[application_server]
API configuration.
This configuration is used to automatically create the:
* Device profile
* Gateways
* Application
* Devices
[application_server.api]
JWT token.
The JWT token to connect to the ChirpStack Application Server API. This
token can be generated using the login API endpoint. In the near-future
it will be possible to generate these tokens within the web-interface:
https://github.com/brocaar/chirpstack-application-server/pull/421
jwt_token=“eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJhdWQiOiJjaGlycHN0YWNrLWFwcGxpY2F0aW9uLXNlcnZlciIsImV4cCI6MTYwNjQyNjU2NSwiaWQiOjEsImlzcyI6ImNoaXJwc3RhY2stYXBwbGljYXRpb24tc2VydmVyIiwibmJmIjoxNjA2MzQwMTY1LCJzdWIiOiJ1c2VyIiwidXNlcm5hbWUiOiJhZG1pbiJ9.42SWTeZTXoKat2sCL9qretRW26YzSeOTbN7z7XkgUTY”
Server.
This must point to the external API server of the ChirpStack Application
Server. When the server is running on the same machine, keep this to the
default value.
Insecure.
Set this to true when the endpoint is not using TLS.
insecure=true
MQTT integration configuration.
This integration is used for counting the number of uplinks that are
published by the ChirpStack Application Server integration.
MQTT server.
Username.
username=""
Password.
password=""
Network Server configuration.
This configuration is used to simulate LoRa gateways using the MQTT gateway
backend.
[network_server]
MQTT gateway backend.
MQTT server.
Username.
username=""
Password.
password=""
Simulator configuration.
Example:
[[simulator]]
# Service-profile ID.
# It is recommended to create a new organization with a new service-profile
# in the ChirpStack Application Server.
service_profile_id=“6689481a-4e01-438c-a8f0-45b6f5adb78b”
# Duration.
# This defines the duration of the simulation. If set to ‘0s’, the simulation
# will run until terminated. This includes the activation time.
duration=“5m”
# Activation time.
# This is the time that the simulator takes to activate the devices. This
# value must be less than the simulator duration.
activation_time=“1m”
# Device configuration.
[simulator.device]
# Number of devices to simulate.
count=5
# Uplink interval.
uplink_interval=“2m”
# FPort.
f_port=10
# Payload (HEX encoded).
payload=“010203”
# Frequency (Hz).
frequency=868100000
# Bandwidth (Hz).
bandwidth=125000
# Spreading-factor.
spreading_factor=7
# Gateway configuration.
[simulator.gateway]
# Event topic template.
event_topic_template=“gateway/{{ .GatewayID }}/event/{{ .Event }}”
# Command topic template.
command_topic_template=“gateway/{{ .GatewayID }}/command/{{ .Command }}”
# Min number of receiving gateways.
min_count=3
# Max number of receiving gateways.
max_count=5
Prometheus metrics configuration.
Using Prometheus (and Grafana), it is possible to visualize various
simulation metrics like:
* Join-Requests sent
* Join-Accepts received
* Uplinks sent (by the devices)
* Uplinks sent (by the gateways)
* Uplinks sent (by the ChirpStack Application Server MQTT integration)
[prometheus]
