I have an Amazon MQ broker running activemq as my MQTT broker. AmazonMQ only supports SSL connections. I have successfully connected to this broker with the latest v3 application-server, the latest v3 network-server, the latest v3 gateway-bridge, v4 gateway-bridge and a mosquitto_sub client and mosquitto_pub client.
Using the same credentials, I can not connect to Amazon MQ with the v4 chirpstack. The logs for Amazon MQ are not very informative:
WARN | Transport Connection to: tcp://84.156.217.243:48022 failed: Invalid message encoding | org.apache.activemq.broker.TransportConnection.Transport | ActiveMQ Transport: ssl:///84.156.217.243:48022
This is a similar message that usually seen when attempting to use a SSL enabled port without SSL or vice versa. But since I have successfully connected with SSL from all those other clients, I’m fairly confident the connection should work.
I have wireshark traces for a successful connection from mosquitto_sub (mosquitto_good_activemq.pcap - Google Drive) and an unsuccessful connection from v4 chirpstack (cs_bad_activemq.pcap - Google Drive).
We were originally thinking that maybe the SSL cipher alg selection was failing, but the wireshark traces make it appear that there is successful encryption occurring.
I was wondering if anyone else came across this issue, or is successfully using Amazon MQ with chirpstack v4?
