It depends using which linux user you’re trying to access this config file. As it contains passwords, it should only be readable by the root or loraserver user. So either change to one of these users or use sudo.
Hello @brocaar. I am trying to access as root user and i also used sudo command as “sudo /etc/loraserver/loraserver.toml”. I also tried to create a new configfile and copy-paste it into /etc/loraserver but i also took response “permission denied”.
I have to say that i made a clean installation today.
Is any possibility to has to do with any error, may occured during installation process?
I am facing the same issue, I am using ubuntu 16.xx as mentioned in the quick install guide.
But when I try to access the /etc/loraserver folder, it say permission denied. I am able to other folders in my /etc folder can you please solve this issue, as I am not able to move ahead with this issue.
Thank you for your response.
I can’t access the loraserver repo.
and when I run the nano or vim command to directly edit the config file, it shows a new file, i.e there is no loraserver.toml file already existing in the loraserver repo. I am facing the same issue when implementing lora-app-server. It has the same issue.
Please help.
