Hi. i started ChirpStack in docker container and tried to connect over API.
In manual I found example only for previous version JavaScript examples - ChirpStack open-source LoRaWAN® Network Server documentation
In my code, I created a connection to the default account (admin/admin) and make connection.
import * as grpc from "@grpc/grpc-js";
import { InternalServiceClient } from "@chirpstack/chirpstack-api/api/internal_grpc_pb";
import { TenantServiceClient } from "@chirpstack/chirpstack-api/api/tenant_grpc_pb";
import { GatewayServiceClient } from "@chirpstack/chirpstack-api/api/gateway_grpc_pb";
import { ListGatewaysRequest } from "@chirpstack/chirpstack-api/api/gateway_pb";
import { LoginRequest, ProfileResponse } from "@chirpstack/chirpstack-api/api/internal_pb";
async function run() {
const url = "127.0.0.1:8080";
const login = "admin";
const password = "admin";
const credentials = grpc.credentials.createInsecure();
const internalService = new InternalServiceClient(
url,
const loginRequest = new LoginRequest();
loginRequest.setEmail(login);
loginRequest.setPassword(password);
const apiToken = await new Promise((resolve, rejects) => {
internalService.login(loginRequest, (error, response) => {
if (error) return rejects(error);
if (response === undefined) return rejects("No value");
const token = response.getJwt();
resolve(token);
////const apiToken = "generate token into account" -doesnt work
const metadata = new grpc.Metadata();
metadata.set("authorization", "Bearer " + apiToken);
const gatewayService = new GatewayServiceClient(url, credentials);
const listRequest = new ListGatewaysRequest();
listRequest.setLimit(99);
listRequest.setOffset(0);
gatewayService.list(listRequest, metadata, (err, value) => {
if (err) return console.error(err);
console.dir(value);
if (!value) return console.error("no value");
console.dir(value.getResultList().map((v) => v.toObject()));
But when I wanted to generate a token in my account (Network Server/API Keys) and establish a connection, I failed. What is the problem?
