Hi!
I installed the gateway bridge on the gateway as described (https://www.chirpstack.io/gateway-bridge/gateway/dragino/), but the status of the gateway goes offline.
I want to ask for help to set the active state.
Version:
Dragino LG308 Firmware: lgw-5.4.1615882321
Chirpstack Gateway Bridge: chirpstack-gateway-bridge_3.10.0-r1_mips_24kc.ipk
I set up the mqtt connection (with user name and password): server=“tcp://xxx.xxx.xxx.xxx:8883”
I set up the LoRaWAN Configuration:
The service is running, ps output:
489 root 16868 R /opt/chirpstack-gateway-bridge/chirpstack-gateway-bridge --config /etc/chirpstack-gateway-bridge/chirpstack-gateway-bridge.toml
I see this in the log:
Fri Mar 26 17:19:11 2021 daemon.info lora_pkt_fwd[858]: Starting Packet Forwarder at 20210326171911
Fri Mar 26 17:19:11 2021 daemon.info lora_pkt_fwd[858]: INFO~ found global configuration file /etc/lora/global_conf.json, parsing it
Fri Mar 26 17:19:11 2021 daemon.info lora_pkt_fwd[858]: INFO~ /etc/lora/global_conf.json does contain a JSON object named SX130x_conf, parsing SX1301 parameters
Fri Mar 26 17:19:11 2021 daemon.info lora_pkt_fwd[858]: INFO~ lorawan_public 1, clksrc 1
Fri Mar 26 17:19:11 2021 daemon.info lora_pkt_fwd[858]: INFO~ no configuration for LBT
Fri Mar 26 17:19:11 2021 daemon.info lora_pkt_fwd[858]: INFO~ antenna_gain 0 dBi
Fri Mar 26 17:19:11 2021 daemon.info lora_pkt_fwd[858]: INFO~ Configuring TX LUT with 16 indexes
Fri Mar 26 17:19:11 2021 daemon.info lora_pkt_fwd[858]: INFO~ radio 0 enabled (type SX1257), center frequency 867500000, RSSI offset -166.000000, tx enabled 1, tx_notch_freq 0
Fri Mar 26 17:19:11 2021 daemon.info lora_pkt_fwd[858]: INFO~ radio 1 enabled (type SX1257), center frequency 868500000, RSSI offset -166.000000, tx enabled 0, tx_notch_freq 0
Fri Mar 26 17:19:11 2021 daemon.info lora_pkt_fwd[858]: INFO~ Lora multi-SF channel 0> radio 1, IF -400000 Hz, 125 kHz bw, SF 7 to 12
Fri Mar 26 17:19:11 2021 daemon.info lora_pkt_fwd[858]: INFO~ Lora multi-SF channel 1> radio 1, IF -200000 Hz, 125 kHz bw, SF 7 to 12
Fri Mar 26 17:19:11 2021 daemon.info lora_pkt_fwd[858]: INFO~ Lora multi-SF channel 2> radio 1, IF 0 Hz, 125 kHz bw, SF 7 to 12
Fri Mar 26 17:19:11 2021 daemon.info lora_pkt_fwd[858]: INFO~ Lora multi-SF channel 3> radio 0, IF -400000 Hz, 125 kHz bw, SF 7 to 12
Fri Mar 26 17:19:11 2021 daemon.info lora_pkt_fwd[858]: INFO~ Lora multi-SF channel 4> radio 0, IF -200000 Hz, 125 kHz bw, SF 7 to 12
Fri Mar 26 17:19:11 2021 daemon.info lora_pkt_fwd[858]: INFO~ Lora multi-SF channel 5> radio 0, IF 0 Hz, 125 kHz bw, SF 7 to 12
Fri Mar 26 17:19:11 2021 daemon.info lora_pkt_fwd[858]: INFO~ Lora multi-SF channel 6> radio 0, IF 200000 Hz, 125 kHz bw, SF 7 to 12
Fri Mar 26 17:19:11 2021 daemon.info lora_pkt_fwd[858]: INFO~ Lora multi-SF channel 7> radio 0, IF 400000 Hz, 125 kHz bw, SF 7 to 12
Fri Mar 26 17:19:11 2021 daemon.info lora_pkt_fwd[858]: INFO~ Lora std channel> radio 1, IF -200000 Hz, 250000 Hz bw, SF 7
Fri Mar 26 17:19:11 2021 daemon.info lora_pkt_fwd[858]: INFO~ FSK channel> radio 1, IF 300000 Hz, 125000 Hz bw, 50000 bps datarate
Fri Mar 26 17:19:11 2021 daemon.info lora_pkt_fwd[858]: INFO~ /etc/lora/global_conf.json does contain a JSON object named gateway_conf, parsing gateway parameters
Fri Mar 26 17:19:11 2021 daemon.info lora_pkt_fwd[858]: INFO~ server hostname or IP address is configured to “router.eu.thethings.network”
Fri Mar 26 17:19:11 2021 daemon.info lora_pkt_fwd[858]: INFO~ upstream port is configured to “1700”
Fri Mar 26 17:19:11 2021 daemon.info lora_pkt_fwd[858]: INFO~ downstream port is configured to “1700”
Fri Mar 26 17:19:11 2021 daemon.info lora_pkt_fwd[858]: INFO~ packets received with a valid CRC will be forwarded
Fri Mar 26 17:19:11 2021 daemon.info lora_pkt_fwd[858]: INFO~ packets received with a CRC error will NOT be forwarded
Fri Mar 26 17:19:11 2021 daemon.info lora_pkt_fwd[858]: INFO~ packets received with no CRC will NOT be forwarded
Fri Mar 26 17:19:11 2021 daemon.info lora_pkt_fwd[858]: INFO~ found local configuration file /etc/lora/local_conf.json, parsing it
Fri Mar 26 17:19:11 2021 daemon.info lora_pkt_fwd[858]: INFO~ redefined parameters will overwrite global parameters
Fri Mar 26 17:19:11 2021 daemon.info lora_pkt_fwd[858]: INFO~ /etc/lora/local_conf.json does not contain a JSON object named SX130x_conf
Fri Mar 26 17:19:11 2021 daemon.info lora_pkt_fwd[858]: INFO~ /etc/lora/local_conf.json does contain a JSON object named gateway_conf, parsing gateway parameters
Fri Mar 26 17:19:11 2021 daemon.info lora_pkt_fwd[858]: INFO~ gateway MAC address is configured to A840411DBEF84150
Fri Mar 26 17:19:11 2021 daemon.info lora_pkt_fwd[858]: INFO~ server hostname or IP address is configured to “localhost”
Fri Mar 26 17:19:11 2021 daemon.info lora_pkt_fwd[858]: INFO~ downstream keep-alive interval is configured to 30 seconds
Fri Mar 26 17:19:11 2021 daemon.info lora_pkt_fwd[858]: INFO~ statistics display interval is configured to 30 seconds
Fri Mar 26 17:19:11 2021 daemon.info lora_pkt_fwd[858]: INFO~ upstream PUSH_DATA time-out is configured to 100 ms
Fri Mar 26 17:19:11 2021 daemon.info lora_pkt_fwd[858]: INFO~ Reference latitude is configured to 22.700000 deg
Fri Mar 26 17:19:11 2021 daemon.info lora_pkt_fwd[858]: INFO~ Reference longitude is configured to 114.240000 deg
Fri Mar 26 17:19:11 2021 daemon.info lora_pkt_fwd[858]: INFO~ Reference altitude is configured to 450 meters
Fri Mar 26 17:19:11 2021 daemon.info lora_pkt_fwd[858]: INFO~ fake GPS is enabled
Fri Mar 26 17:19:11 2021 daemon.info lora_pkt_fwd[858]: INFO~ Beaconing period is configured to 0 seconds
Fri Mar 26 17:19:11 2021 daemon.info lora_pkt_fwd[858]: INFO~ Beaconing signal will be emitted at 869525000 Hz
Fri Mar 26 17:19:11 2021 daemon.info lora_pkt_fwd[858]: INFO~ Beaconing datarate is set to SF9
Fri Mar 26 17:19:11 2021 daemon.info lora_pkt_fwd[858]: INFO~ Beaconing modulation bandwidth is set to 125000Hz
Fri Mar 26 17:19:11 2021 daemon.info lora_pkt_fwd[858]: INFO~ Beaconing TX power is set to 14dBm
Fri Mar 26 17:19:11 2021 daemon.info lora_pkt_fwd[858]: INFO~ Beaconing information descriptor is set to 0
Fri Mar 26 17:19:11 2021 daemon.info lora_pkt_fwd[858]: INFO~ sockfd=3
Fri Mar 26 17:19:11 2021 daemon.info lora_pkt_fwd[858]: INFO~ sockfd=4
Fri Mar 26 17:19:11 2021 daemon.info lora_pkt_fwd[858]: INFO~ FPort Filter: 0
Fri Mar 26 17:19:11 2021 daemon.info lora_pkt_fwd[858]: INFO~ DevAddrMask: 0x0
Fri Mar 26 17:19:11 2021 daemon.info lora_pkt_fwd[858]: INFO~ ABP Decryption: no
Fri Mar 26 17:19:11 2021 daemon.info lora_pkt_fwd[858]: INFO~ sx1276:0, sxtxpw:0, model:LG08, server_type:lorawan
Thanks,
Feri
