Problem with gateway location map rendering
I noticed a map rendering issue when configuring a gateway:
This is consistent on the latest versions of Chrome and Firefox.
PS - In spite of the rendering issue, it would be nice to be able to just paste in the GPS coordinates rather than dragging the marker to the location on the map.
In my case, i even could able to seen any map.
I am wondering what should be the issue. I am using LG01-P as gateway
From my experience it is internet issue not downloading the tiles. I also agree with Eric above the ability to paste in the co-ordinates would be far easier and more accurate than moving the pin, esp as I have to take the gateway with me to various locations for various reasons.
You are not having a problem with tiles, you are just seeing the map zoomed and centered at (0, 0), which happens to be in the ocean.
You can go to the configuration tab and then click set to current location :slight_smile:
I just had the same ‘issue’. Map zoomed to 0,0
set to current location didn’t do anything though.
Zooming out, and manually moving the pin worked.
Problem solved
I faced the same problem.
Using current location was blocked in browser (chrome). I allowed it to use my current location and map was rendered successfully.
It seems that there is a bug within js code that avoids map to be configured correctly while the permission is not given.
If you don’t give the permission, then the JS code can’t get it :wink: You can zoom out however and drag the marker yourself.
Yea It’s true but as far as I know, user-side mistake can be handle by setting lower zoom level as default value.
Thanks for following up @brocaar
@my_location
check if your browser is up to date and verify the gateway configuration for any potential errors; and, while pasting GPS coordinates for map markers might not be directly supported in the current configuration, you can consider providing feedback to the development team for potential feature enhancements.
