Problem with Versions > 4.3.2
we have an Version 4.2.x installation that we wanted to upgrade (it was never a 3.x). We have upgraded to 4.3.2 which works fine but any version later than that do not work. I just see this log output:
> 2024-04-09T14:22:56.946787Z  INFO chirpstack::cmd::root: Starting ChirpStack LoRaWAN Network Server version="4.4.0" docs="https://www.chirpstack.io/"
> 2024-04-09T14:22:56.946819Z  INFO chirpstack::storage: Setting up PostgreSQL connection pool
> 2024-04-09T14:22:56.961413Z  INFO chirpstack::storage: Applying schema migrations
> 2024-04-09T14:22:56.962437Z  INFO chirpstack::storage: Setting up Redis client
> 2024-04-09T14:22:56.986908Z  INFO chirpstack::region: Setting up regions
> 2024-04-09T14:22:56.986934Z  INFO chirpstack::backend::joinserver: Setting up Join Server clients
> 2024-04-09T14:22:56.986938Z  INFO chirpstack::backend::roaming: Setting up roaming clients
> 2024-04-09T14:22:56.986942Z  INFO chirpstack::adr: Setting up adr algorithms
> 2024-04-09T14:22:56.986968Z  INFO chirpstack::integration: Setting up global integrations
> 2024-04-09T14:22:56.986973Z  INFO chirpstack::integration::redis: Initializing Redis integration
> 2024-04-09T14:22:56.986981Z  INFO chirpstack::integration::mqtt: Initializing MQTT integration
> 2024-04-09T14:22:56.989974Z  INFO chirpstack::integration::mqtt: Connecting to MQTT broker server_uri=tcp://chirpstack-mosquitto-mosquitto:1883/ client_id=9954eaa186efb525 clean_session=false
> 2024-04-09T14:22:57.100855Z  INFO chirpstack::integration::mqtt: Connected to MQTT broker
> 2024-04-09T14:22:57.100987Z  INFO chirpstack::gateway::backend: Setting up gateway backends for the different regions
> 2024-04-09T14:22:57.101007Z  INFO chirpstack::downlink: Setting up Class-B/C scheduler loop
> 2024-04-09T14:22:57.101013Z  INFO chirpstack::downlink: Setting up multicast scheduler loop
> 2024-04-09T14:22:57.101011Z  INFO chirpstack::integration::mqtt: Starting MQTT consumer loop
> 2024-04-09T14:22:57.101014Z  INFO chirpstack::integration::mqtt: Subscribing to command topic command_topic=application/+/device/+/command/+
> 2024-04-09T14:22:57.101020Z  INFO chirpstack::api: Setting up API interface bind=0.0.0.0:8080
> 2024-04-09T14:22:57.101049Z  INFO chirpstack::api::backend: Setting up backend interfaces API bind=0.0.0.0:8090
> 2024-04-09T14:22:57.101100Z  INFO chirpstack::api::monitoring: Setting up monitoring endpoint bind=0.0.0.0:8081
No error, the server just does not process any traffic. Looking at the change-log I cannot spot anything that would explain this.
Would love to get some hint on what could be wrong.
BG, Thomas
Have you upgraded chirpstack-gateway-bridge as well?
Need to doublecheck all toml files as the toml files may not keep your changes.
I have upgraded 3-4 times from v4.0 to 4.7 and it still works after some minor comfiguration changes.
Yes, I’m even running latest GW bridge and latest API Service. I just cannot upgrade the CS service itself. The problem is, I cannot find any config changes that are due. If I read the documentation for 4.7 it looks to me like I have everything in place. The topic names have not changed.
Here is my config for reference:
    # Logging.
    [logging]
      # Log level.
      level="info"
    # PostgreSQL configuration.
    [postgresql]
      # PostgreSQL DSN.
      # SSL mode options:
      #  * disable - no SSL
      #  * require - Always SSL (skip verification)
      #  * verify-ca - Always SSL (verify that the certificate presented by the server was signed by a trusted CA)
      #  * verify-full - Always SSL (verify that the certification presented by the server was signed by a trusted CA and the server host name matches the one in the certificate)
      # dsn="postgresql://chirpstack:chirpstack@localhost/chirpstack?sslmode=disable"
      dsn="$POSTGRESQL_DSN"
      # Max open connections.
      # PostgreSQL connection pool.
      max_open_connections=10
      # Min idle connections.
      min_idle_connections=0
    # Redis configuration.
    [redis]
      servers=["{{ join "\",\"" .Values.chirpstack.redis.servers }}"]
      # Redis Cluster.
      # instance.
      cluster=false
      # Key prefix.
      # A key prefix can be used to avoid key collisions when multiple deployments
      # are using the same Redis database and it is not possible to separate
      # keys by database index (e.g. when using Redis Cluster, which does not
      # support multiple databases).
      key_prefix=""
      # Redis connection pool.
      max_open_connections=100
      # This sets the min. number of idle connections in the Redis connection
    [api]
      bind="0.0.0.0:8080"
      # Secret.
      #   openssl rand -base64 32
      secret=""
    # Global gateway configuration.
    # Please note that backend configuration can be found in the per-region
    # configuration.
    [gateway]
      # CA certificate and key file (optional).
      # If setting the CA certificate and key file options, ChirpStack
      # will generate client certificates which can be used by the gateway for
      # authentication and authorization. The Common Name of the certificate will
      # be set to the Gateway ID.
      ca_key=""
      ca_cert=""
      # Certificate lifetime.
      # This defines how long (after generating) the certificate remains valid.
      client_cert_lifetime="11months 30days 3h 50m 24s"
    [network]
      net_id="000000"
      # Enabled regions.
      enabled_regions=[
        "eu433",
        "eu868",
        "us915_0",
      # Device session expiration.
      # The TTL value defines the time after which a device-session expires
      # after no activity.
      device_session_ttl="1month 13h 26m 24s"
      # Time to wait for uplink de-duplication.
      # This is the time that ChirpStack will wait for other gateways to receive
      # the same uplink frame. Please note that this value affects the
      # roundtrip time. The total roundtrip time (which includes network latency)
      # must be less than the (first) receive-window.
      deduplication_delay="200ms"
      # Mac-commands disabled.
      mac_commands_disabled=false
      # Scheduler settings.
      [network.scheduler]
        # Scheduler interval.
        # The interval in which the downlink scheduler for multicast, Class-B and
        # Class-C runs.
        interval="1s"
        # Class-A lock duration.
        # This defines the lock duration between receiving a Class-A uplink and
        # the next scheduler-run for a device. The purpose of this lock is to
        # avoid collisions between Class-A and Class-B/C downlinks.
        class_a_lock_duration="5s"
        # Class-C lock duration.
        # This defines the lock duration between scheduling two Class-C downlink
        # payloads for the same device. The purpose of this lock is to avoid
        # overlap between scheduling Class-C downlinks and / or spreading the
        # downlink capacity load on the gateway.
        class_c_lock_duration="5s"
        # Multicast Class-C use GPS time.
        # Use GPS time for scheduling multicast class-c downlinks. If this is enabled
        # and the downlink must be send by multiple gateways to cover all devices
        # within the multicast-group, these downlinks will be sent at exactly the same
        # time by these gateways. If disabled, ChirpStack will use the configured
        # margin. Only enable this features when all gateways have GNSS support.
        multicast_class_c_use_gps_time=false
        # Multicast Class-C margin.
        # This defines the minimum margin between scheduling multiple multicast downlinks
        # (within the same multicast-group). This value must be equal or greater than the
        # scheduler interval.
        multicast_class_c_margin="5s"
        # Multicast Class-B margin.
        multicast_class_b_margin="5s"
    # Monitoring related configuration.
    [monitoring]
      # interface:port to bind the monitoring endpoint to (optional).
      # /health  - Returns 200 in case the healthchecks have passed.
      # /metrics - Returns metrics which can be scraped by Prometheus.
      # If not set, this endpoint will be disabled.
      bind="0.0.0.0:8081"
      # Meta-log max history.
      # This defines the max number of meta records that will be persisted in Redis Streams.
      # Setting this value to 0 disables this feature.
      meta_log_max_history=10
      # Gateway frame-log max history.
      # This defines the max number of frame-log records that will be persisted in Redis Streams.
      # This stream contains the uplink and downlink frames of all gateways.
      gateway_frame_log_max_history=10
      # Device frame-log max history.
      # This stream contains the uplink and downlink frames of all devices.
      device_frame_log_max_history=10
      # Device event-log max history.
      # This defines the max number of event-log records that will be persisted in Redis Streams.
      # This stream contains the events of all devices.
      device_event_log_max_history=10
      # Per gateway frame-log max history.
      # Equal to the gateway_frame_log_max_history, but for each gateway a new Redis Stream
      # is created.
      per_gateway_frame_log_max_history=10
      # Per gateway frame-log TTL.
      # This defines the TTL of the Redis Stream key.
      per_gateway_frame_log_ttl="1month 13h 26m 24s"
      # Per device frame-log max history.
      # Equal to the device_frame_log_max_history, but for each device a new Redis Stream
      # is created.
      per_device_frame_log_max_history=10
      # Per device frame-log TTL.
      per_device_frame_log_ttl="1month 13h 26m 24s"
      # Per device event-log max history.
      # Equal to the device_event_log_max_history, but for each device a new Redis Stream
      # is created.
      per_device_event_log_max_history=10
      # Per device event-log TTL.
      per_device_event_log_ttl="1month 13h 26m 24s"
    # Global integration related configuration.
    [integration]
      # Enabled integrations (global).
      enabled = [
        "mqtt"
      # MQTT integration configuration.
      [integration.mqtt]
        # Event topic template.
        event_topic={{`"application/{{application_id}}/device/{{dev_eui}}/event/{{event}}"`}}
        # Command topic.
        # This is the topic on which the MQTT subscribes for receiving (enqueue) commands.
        command_topic={{`"application/{{application_id}}/device/{{dev_eui}}/command/{{command}}"`}}
        # Use JSON encoding instead of Protobuf (binary).
        json=false
        server="tcp://{{ .Values.chirpstack.integration.mqtt.server.host }}:1883/"
        username=""
        password=""
        # Quality of service level
        # 0: at most once
        # 1: at least once
        # 2: exactly once
        qos=0
        # Clean session
        clean_session=false
        # Client ID
        # broker. A client id must be no longer than 23 characters. If left blank,
        # a random id will be generated by ChirpStack.
        client_id=""
        ca_cert=""
        tls_cert=""
        # TLS key file (optional)
        tls_key=""
I do miss one log item in this logs, the subscribe to the gateway events, e.g. you should see something like:
2024-04-11T08:54:59.127469Z  INFO chirpstack::gateway::backend::mqtt: Connecting to MQTT broker region_id=eu868 server_uri=tcp://localhost:1883 clean_session=false client_id=1d62d6dc120aac49
2024-04-11T08:54:59.127931Z  INFO chirpstack::gateway::backend::mqtt: Starting MQTT event loop
2024-04-11T08:54:59.129795Z  INFO chirpstack::gateway::backend::mqtt: Subscribing to gateway event topic region_id=eu868 event_topic=$share/chirpstack/eu868/gateway/+/event/
So it looks like there is a config issue with your regions, because of that ChirpStack does not receive any gateway traffic.
The thing is I have not changed anything in the config and I just Upgrade from 4.3.2 to 4.4.0 and it stops working. Was there any change in the config schema?
@brocaar I think I’ve found the reason. The docker image > v4.4.0 seems to muss all [[regions]] files in the /etc folder. Is that intended?
The problem is clearly that all the config files are missing in container images > 4.3.2:
Version 4.3.2 container image:
Version 4.7.0 container image:
This was removed in this commit:
was this intended?
The reason might have been that originally, all database and mqtt broker hosts configs where using env variables (e.g. server="$MQTT_BROKER_HOST"), which did not work very well and was reverted. There is not really any value in including configuration that doesn’t work (e.g. server="tcp://localhost:1883" does not work within Docker as the container itself does not provide a MQTT broker). So probably that is why it was taken out and the config was added to the chirpstack-docker repo.
ok, many thanks. A note in the Change log would have been helpful however.
