Does anyone know of a secure way for connecting a prometheus server to the the gateway that is in the field running the packet forwarder and gateway bridge and not at a static address? Having trouble identifying the best way to manage the address and connection.
Current setup is a Tektelic Micro Gateway, Azure IoT Hub, service bus and azure virtual machines hosting prometheus and the network and application servers.
PushProx has a few noted security issues and I was unable to deploy this on the gateway, I think primarily due to the limited OS on the unit.
I followed these instructions for the OpenVPN - https://openvpn.net/vpn-server-resources/connecting-to-access-server-with-linux/
I built out the OpenVPN connection and setup a persistent tunnel with a static IP. OpenVPN does allow for two connections for free before you need to purchase a license pack. At that point, you’re looking at a minimum of 10 licenses.
After this was all built out I could compare gateway metrics, compare to the cloud metrics to identify communication issues and see the uptime status of the gateway in a grafana dashboard.
Would be great to hear any improvements on this solution!
