I’m trying to add V4 support to a webhook service, which already has V3 support. I’ve added the V4 handler and proto unmarshaller as described in HTTP - ChirpStack open-source LoRaWAN® Network Server documentation.
When trying to compile I’m getting the following error:
GOROOT=/home/jpmeijers/sdk/go1.19.3 #gosetup
GOPATH=/home/jpmeijers/go #gosetup
/home/jpmeijers/sdk/go1.19.3/bin/go build -o /home/jpmeijers/.cache/JetBrains/GoLand2023.3/tmp/GoLand/___go_build_ttnmapper_ingress_api . #gosetup
panic: proto: file "common/common.proto" is already registered
See https://protobuf.dev/reference/go/faq#namespace-conflict
goroutine 1 [running]:
google.golang.org/protobuf/reflect/protoregistry.glob..func1({0x13fb440?, 0xc000265110?}, {0x13fb440?, 0xc000265110})
/home/jpmeijers/GolandProjects/ttnmapper-ingress-api/vendor/google.golang.org/protobuf/reflect/protoregistry/registry.go:56 +0x1ee
google.golang.org/protobuf/reflect/protoregistry.(*Files).RegisterFile(0xc0000121f8, {0x1414d80?, 0xc000274540?})
/home/jpmeijers/GolandProjects/ttnmapper-ingress-api/vendor/google.golang.org/protobuf/reflect/protoregistry/registry.go:130 +0x39f
google.golang.org/protobuf/internal/filedesc.Builder.Build({{0xfc99e8, 0x31}, {0x1c69d00, 0x636, 0x636}, 0x9, 0x4, 0x0, 0x0, {0x1402cd0, ...}, ...})
/home/jpmeijers/GolandProjects/ttnmapper-ingress-api/vendor/google.golang.org/protobuf/internal/filedesc/build.go:112 +0x1d6
google.golang.org/protobuf/internal/filetype.Builder.Build({{{0xfc99e8, 0x31}, {0x1c69d00, 0x636, 0x636}, 0x9, 0x4, 0x0, 0x0, {0x0, ...}, ...}, ...})
/home/jpmeijers/GolandProjects/ttnmapper-ingress-api/vendor/google.golang.org/protobuf/internal/filetype/build.go:138 +0x1b8
github.com/chirpstack/chirpstack/api/go/v4/common.file_common_common_proto_init()
/home/jpmeijers/GolandProjects/ttnmapper-ingress-api/vendor/github.com/chirpstack/chirpstack/api/go/v4/common/common.pb.go:1075 +0x1d8
github.com/chirpstack/chirpstack/api/go/v4/common.init.0()
/home/jpmeijers/GolandProjects/ttnmapper-ingress-api/vendor/github.com/chirpstack/chirpstack/api/go/v4/common/common.pb.go:1006 +0x17
Process finished with the exit code 2
As per the Go FAQ, I tried moving the V3 and V4 handlers into separate packages, but I’m still getting this same error.
Does anyone have a suggestion how to solve this error properly, without resorting to using
go build -ldflags "-X google.golang.org/protobuf/reflect/protoregistry.conflictPolicy=warn"
or
GOLANG_PROTOBUF_REGISTRATION_CONFLICT=warn ./main ?
My code can be found at GitHub - ttnmapper/ingress-api at feature/chirpstackV4
Update
When compiling the service with google.golang.org/protobuf/reflect/protoregistry.conflictPolicy=warn the output looks much different, mentioning many more protos colliding. So far the unmarshalling does seem to work correctly.
/home/jpmeijers/sdk/go1.19.3/bin/go build -ldflags -X google.golang.org/protobuf/reflect/protoregistry.conflictPolicy=warn -o /home/jpmeijers/.cache/JetBrains/GoLand2023.3/tmp/GoLand/___1go_build_ttnmapper_ingress_api . #gosetup
WARNING: proto: file "common/common.proto" is already registered
WARNING: proto: file "common/common.proto" has a name conflict over common.LocationSource
WARNING: proto: file "common/common.proto" has a name conflict over common.GEO_RESOLVER_WIFI
WARNING: proto: file "common/common.proto" has a name conflict over common.GEO_RESOLVER_GNSS
WARNING: proto: file "common/common.proto" has a name conflict over common.GEO_RESOLVER_RSSI
WARNING: proto: file "common/common.proto" has a name conflict over common.GEO_RESOLVER_TDOA
WARNING: proto: file "common/common.proto" has a name conflict over common.CONFIG
WARNING: proto: file "common/common.proto" has a name conflict over common.GPS
WARNING: proto: file "common/common.proto" has a name conflict over common.UNKNOWN
WARNING: proto: file "common/common.proto" has a name conflict over common.MType
WARNING: proto: file "common/common.proto" has a name conflict over common.Region
WARNING: proto: file "common/common.proto" has a name conflict over common.ISM2400
WARNING: proto: file "common/common.proto" has a name conflict over common.RU864
WARNING: proto: file "common/common.proto" has a name conflict over common.IN865
WARNING: proto: file "common/common.proto" has a name conflict over common.KR920
WARNING: proto: file "common/common.proto" has a name conflict over common.AS923_4
WARNING: proto: file "common/common.proto" has a name conflict over common.AS923_3
WARNING: proto: file "common/common.proto" has a name conflict over common.AS923_2
WARNING: proto: file "common/common.proto" has a name conflict over common.CN470
WARNING: proto: file "common/common.proto" has a name conflict over common.AU915
WARNING: proto: file "common/common.proto" has a name conflict over common.EU433
WARNING: proto: file "common/common.proto" has a name conflict over common.CN779
WARNING: proto: file "common/common.proto" has a name conflict over common.US915
WARNING: proto: file "common/common.proto" has a name conflict over common.EU868
WARNING: proto: file "common/common.proto" has a name conflict over common.Modulation
WARNING: proto: file "common/common.proto" has a name conflict over common.LR_FHSS
WARNING: proto: file "common/common.proto" has a name conflict over common.FSK
WARNING: proto: file "common/common.proto" has a name conflict over common.LORA
WARNING: proto: file "common/common.proto" has a name conflict over common.KeyEnvelope
WARNING: proto: message common.Location is already registered
WARNING: proto: message common.KeyEnvelope is already registered
WARNING: proto: file "gw/gw.proto" is already registered
WARNING: proto: file "gw/gw.proto" has a name conflict over gw.TxAckStatus
WARNING: proto: file "gw/gw.proto" has a name conflict over gw.INTERNAL_ERROR
WARNING: proto: file "gw/gw.proto" has a name conflict over gw.QUEUE_FULL
WARNING: proto: file "gw/gw.proto" has a name conflict over gw.GPS_UNLOCKED
WARNING: proto: file "gw/gw.proto" has a name conflict over gw.TX_POWER
WARNING: proto: file "gw/gw.proto" has a name conflict over gw.TX_FREQ
WARNING: proto: file "gw/gw.proto" has a name conflict over gw.COLLISION_BEACON
WARNING: proto: file "gw/gw.proto" has a name conflict over gw.COLLISION_PACKET
WARNING: proto: file "gw/gw.proto" has a name conflict over gw.TOO_EARLY
WARNING: proto: file "gw/gw.proto" has a name conflict over gw.TOO_LATE
WARNING: proto: file "gw/gw.proto" has a name conflict over gw.OK
WARNING: proto: file "gw/gw.proto" has a name conflict over gw.IGNORED
WARNING: proto: file "gw/gw.proto" has a name conflict over gw.CRCStatus
WARNING: proto: file "gw/gw.proto" has a name conflict over gw.CRC_OK
WARNING: proto: file "gw/gw.proto" has a name conflict over gw.BAD_CRC
WARNING: proto: file "gw/gw.proto" has a name conflict over gw.NO_CRC
WARNING: proto: file "gw/gw.proto" has a name conflict over gw.FineTimestampType
WARNING: proto: file "gw/gw.proto" has a name conflict over gw.PLAIN
WARNING: proto: file "gw/gw.proto" has a name conflict over gw.ENCRYPTED
WARNING: proto: file "gw/gw.proto" has a name conflict over gw.NONE
WARNING: proto: file "gw/gw.proto" has a name conflict over gw.DownlinkTiming
WARNING: proto: file "gw/gw.proto" has a name conflict over gw.GPS_EPOCH
WARNING: proto: file "gw/gw.proto" has a name conflict over gw.DELAY
WARNING: proto: file "gw/gw.proto" has a name conflict over gw.IMMEDIATELY
WARNING: proto: file "gw/gw.proto" has a name conflict over gw.ConnState
WARNING: proto: file "gw/gw.proto" has a name conflict over gw.RawPacketForwarderCommand
WARNING: proto: file "gw/gw.proto" has a name conflict over gw.RawPacketForwarderEvent
WARNING: proto: file "gw/gw.proto" has a name conflict over gw.GatewayCommandExecResponse
WARNING: proto: file "gw/gw.proto" has a name conflict over gw.GatewayCommandExecRequest
WARNING: proto: file "gw/gw.proto" has a name conflict over gw.ChannelConfiguration
WARNING: proto: file "gw/gw.proto" has a name conflict over gw.GatewayConfiguration
WARNING: proto: file "gw/gw.proto" has a name conflict over gw.DownlinkFrameItem
WARNING: proto: file "gw/gw.proto" has a name conflict over gw.UplinkFrameSet
WARNING: proto: file "gw/gw.proto" has a name conflict over gw.GPSEpochTimingInfo
WARNING: proto: file "gw/gw.proto" has a name conflict over gw.DelayTimingInfo
WARNING: proto: file "gw/gw.proto" has a name conflict over gw.ImmediatelyTimingInfo
WARNING: proto: file "gw/gw.proto" has a name conflict over gw.PerModulationCount
WARNING: proto: file "gw/gw.proto" has a name conflict over gw.GatewayStats
WARNING: proto: file "gw/gw.proto" has a name conflict over gw.PlainFineTimestamp
WARNING: proto: file "gw/gw.proto" has a name conflict over gw.EncryptedFineTimestamp
WARNING: proto: file "gw/gw.proto" has a name conflict over gw.Modulation
WARNING: proto: message gw.Modulation is already registered
WARNING: proto: message gw.EncryptedFineTimestamp is already registered
WARNING: proto: message gw.PlainFineTimestamp is already registered
WARNING: proto: message gw.GatewayStats is already registered
WARNING: proto: message gw.PerModulationCount is already registered
WARNING: proto: message gw.ImmediatelyTimingInfo is already registered
WARNING: proto: message gw.DelayTimingInfo is already registered
WARNING: proto: message gw.GPSEpochTimingInfo is already registered
WARNING: proto: message gw.UplinkFrame is already registered
WARNING: proto: message gw.UplinkFrameSet is already registered
WARNING: proto: message gw.DownlinkFrame is already registered
WARNING: proto: message gw.DownlinkFrameItem is already registered
WARNING: proto: message gw.GatewayConfiguration is already registered
WARNING: proto: message gw.ChannelConfiguration is already registered
WARNING: proto: message gw.GatewayCommandExecRequest is already registered
WARNING: proto: message gw.GatewayCommandExecResponse is already registered
WARNING: proto: message gw.RawPacketForwarderEvent is already registered
WARNING: proto: message gw.RawPacketForwarderCommand is already registered
WARNING: proto: message gw.ConnState is already registered
WARNING: proto: file "integration/integration.proto" has a name conflict over integration.DOWNLINK_GATEWAY
WARNING: proto: file "integration/integration.proto" has a name conflict over integration.UPLINK_MIC
WARNING: proto: file "integration/integration.proto" has a name conflict over integration.OTAA
WARNING: proto: file "integration/integration.proto" has a name conflict over integration.DOWNLINK_CODEC
WARNING: proto: file "integration/integration.proto" has a name conflict over integration.UPLINK_CODEC
WARNING: proto: file "integration/integration.proto" has a name conflict over integration.DOWNLINK_PAYLOAD_SIZE
WARNING: proto: file "integration/integration.proto" has a name conflict over integration.UNKNOWN
WARNING: proto: file "integration/integration.proto" has a name conflict over integration.IntegrationEvent
WARNING: proto: file "integration/integration.proto" has a name conflict over integration.LocationEvent
WARNING: proto: file "integration/integration.proto" has a name conflict over integration.StatusEvent
WARNING: proto: file "integration/integration.proto" has a name conflict over integration.TxAckEvent
WARNING: proto: file "integration/integration.proto" has a name conflict over integration.AckEvent
WARNING: proto: file "integration/integration.proto" has a name conflict over integration.JoinEvent
WARNING: proto: file "integration/integration.proto" has a name conflict over integration.UplinkEvent
WARNING: proto: message integration.UplinkEvent is already registered
WARNING: proto: message integration.JoinEvent is already registered
WARNING: proto: message integration.AckEvent is already registered
WARNING: proto: message integration.TxAckEvent is already registered
WARNING: proto: message integration.StatusEvent is already registered
WARNING: proto: message integration.LocationEvent is already registered
WARNING: proto: message integration.IntegrationEvent is already registered
