Publishing downlink Message in Python problem
Hello!
I have been trying to the Pahos Python client to send a downlink message to a device I have built. I have successfully done this through the Chirpstack enqueue interface as well as the node-red application. However, I have found that all the examples I have found to do this in python do not work for me and actually have competing syntax:
They almost always use Port:1883 The node-red application uses 8080.
Node-red uses an API key and none of the examples show how to use this information.
They all vary with using quotation marks, topic structure ( /command/down vs /Device ID/down), if the message has to be json encoded, etc.
I have read all the mosquito documentation,2 books on the pathos client and mosquito, Chirpstack, TTN, Semtech chats, and somehow I have missed how to do this seemly easy thing to do. The documentation there but no real examples…particularly on API Key from what I found.
I can successfully subscribe to all the device events and I can see that the node-red message gets sent successfully, but I can not see the actual message it is sending which I understand is not python.
Does anyone have a small python stub on how to do this that they can point me to?
Thank you in advance
Do you mean something like this? :slight_smile: Python examples - ChirpStack open-source LoRaWAN® Network Server documentation
Exactly!..Thank you! This is the only example I could get to work…
-B
