I tried Gateway configuration using Pygate + Lopy4. I am able to join this gateway using built-in wifi module to TTN but can i use the same as Gateway connecting to Private LoRa Network?
Yes…
in your PYGATE config.json, you just have to modify:
"gateway_conf": {
"gateway_ID": "XXXXXXXXXXXXXXXX",
"server_address": "local.ip.chirpstack.address", ---> local ip defined in your local chirpstack server
"serv_port_up": 1700, ---> local port defined in your local chirpstack server
"serv_port_down": 1700, ---> local port defined in your local chirpstack server
"keepalive_interval": 10,
"stat_interval": 30,
"push_timeout_ms": 100,
"forward_crc_valid": true,
"forward_crc_error": false,
"forward_crc_disabled": false
Thanks for the information et me check the same.
Can you tell how to connect to wifi using Lopy4 pygate
You’ll find all the information into this link: GitHub - MarinoMtz/Pygate: Pygate with chirpstack gateway bridge
Able to connect my Pcom+Lopy4 based nano gateway to
- TTN Network
- Chirpstack - Local implementation
- AWS LoRa
