I try to read my devices with python and the chirpstack-api library. I am successful in requesting applications, device_grofiles, gateways, list from devices in an application but if I want to request details from a specifig device I get an error.
This is a working code for requesting applications
import grpc
from chirpstack_api import api as chirpstack
with open(chirpstack_pem, "rb") as f:
credentials = grpc.ssl_channel_credentials(f.read())
channel = grpc.secure_channel(chirpstack_server, credentials)
auth_token = [("authorization", "Bearer %s" % chirpstack_token)]
if __name__ == "__main__":
client = chirpstack.ApplicationServiceStub(channel)
req = chirpstack.ListApplicationsRequest()
req.limit = 10 #mandatory if you want details
req.offset = 0
req.tenant_id = tenant_id
resp = client.List(req, metadata=auth_token)
print(resp)
Here the code to request a single device
import grpc
client = chirpstack.DeviceServiceStub(channel)
req = chirpstack.GetDeviceRequest()
req.dev_eui = "343233386B376510"
print(resp)
And this is the error I get:
Traceback (most recent call last):
File "C:\Users\ckroon\PycharmProjects\chripstack\chirpstack_device.py", line 21, in <module>
File "C:\Users\ckroon\PycharmProjects\chripstack\venv\lib\site-packages\grpc\_channel.py", line 1160, in __call__
return _end_unary_response_blocking(state, call, False, None)
File "C:\Users\ckroon\PycharmProjects\chripstack\venv\lib\site-packages\grpc\_channel.py", line 1003, in _end_unary_response_blocking
raise _InactiveRpcError(state) # pytype: disable=not-instantiable
grpc._channel._InactiveRpcError: <_InactiveRpcError of RPC that terminated with:
status = StatusCode.INTERNAL
details = "failed to decode Protobuf message: ListDevicesRequest.limit: invalid wire type: LengthDelimited (expected Varint)"
debug_error_string = "UNKNOWN:Error received from peer {grpc_message:"failed to decode Protobuf message: ListDevicesRequest.limit: invalid wire type: LengthDelimited (expected Varint)", grpc_status:13, created_time:"2024-02-09T12:59:42.8224533+00:00"}"
Process finished with exit code 1
What could I do to get the correct information? I have the same issue with requesting the device key’s.
