I noticed that the lastSeenAt property on gateways is updated only when a stat packet arrives. Is there a reason why this property is not updated when other regular frames are received ? We could consider the gateway is also seen at that time ?
The reason behind this question is that stats packet are sent at a frequency determined by the gateway packet forwarder. Sometimes the stat packet happen much later than when the first frames are received. As we use the last seen property in our application to display if a gateway is “online”, it could be more precise if it was updated for regular packets as well.
Another related question: for the moment we regularly poll gateways through the API to get their last seen, to display them as online or offline. Is there a way to be notified when the last seen changes or is polling the only way ?
Thanks
