Wireshark on the host sees no unicast traffic arriving from this GW to the host’s 192.168.128.133 interface, but does capture some multicast traffic from the GW. No changes were made to docker-compose.yml, which exposes port 1700 for the GW bridge.
I believe Wireshark sees any traffic prior to the firewall, so FW should not be impacting what I see in Wireshark. However, I did confirm that port 1700 (GW bridge) is open for UDP. All I am seeing in Wireshark is a few MDNS queries and responses issued from the GW at 192.168.128.134.
This is starting to smell more like this is a problem with the RAK.
Hello @WoobaGooba could you share your lora-gateway-bridge.toml?
I have same problem, but i assure my global and local_conf.json is to loraserver (just like you did, i was used TTN before)
