I’m using RAK2245 hat with Raspberry pi and chirpstack-gateway-os. I’m happily receiving uplinks from 1.5km+ range. However, when sent downlink, sensor can’t receive it from the same range. Upper limit is 700 meters. When I check logs I can see that uplink in sent with 20 dBm, SF and bandwidth are according to regional params and rx2_dr_offset. Is there any way to increase output power to 27 dBm? I think this is done in lower layer (packet-forwarder?) but I can’t find any tx power configuration.
# Downlink TX Power (dBm)
# be used.
downlink_tx_power=-1
it depends on which packet forwarder you’re using. In case of poly_pkt_fwd or lora_pkt_fwd, you can edit the global_conf.json “rf_power”: parameters in tx_lut_ sections but it is not recommended. backup it before editing. or add the corresponding data into local_conf.json
