Hi
I’m running a couple of RisingHF301 gateway’s connected via 3g to my dedicated Server via SSL port 8883. The server runs Centos 7 and every works like clockwork. From the MQTT to the application server and Network server receiving the packets. I’m very happy with the Gateway and Server Setup.
I brought RAK2247 gateways recently to add them as well and ran into some with the trouble as I’m using the https://github.com/RAKWireless/rak_common_for_gateway installed and configured on the 2020-12-02-raspios-buster-armhf-full OS.
I’m having trouble to configure the SSL Certs on it. Is there any direction you can guide me in to so I can add the certs for SSL to communicate with my server. It has the ca.pem, cert.pem and key.pem allready working with the other RisingHF’s. I just need to know how to do it from
rak_common_for_gateway side on the gateway itself.
Thanks
