I am running into sporadic UFW BLOCK errors in my syslog. This is resulting in data not getting to chirpstack. I have confirmed that the sensor is not the issue by confirming the FCNT is incrementing. This was also confirmed with the sensor vendor.
I have the UFW enabled with access to ports 8080, 1700, 8086 and 8087.
I have taken a look at the gateway router and checked the logs. I do not see anything there that would indicate it was resetting.
I am running chirpstackv4 on ubuntu 22.04 LTS.
Any ideas or support would be much welcomed. This is resulting in inconsistent data reporting.
Hi @jidggins ,
Can you share your logs regarding UFW BLOCK error and the corresponding missing frames in the events of the sensor in Chirpstack?
@Jerome73 for context the issue I am trying to resolve is random loss of data between the gateway and gateway server. This tends to happen at off hours. Although, this morning the gateway can not connect for several hours. I rebooted the gateway, router, and server. It seemed to fix it for a short period of time and now has failed to connect again.
I have confirmed it is not the end devices as the FCNT increases or resets with confirmed FCNT. So I do believe it is between the gateway server and gateway.
You can see the loss of date after 8/1 00:43:18 through 8/1 8/1 07:23:13. The FCNT increase during this time which confirms the end device is working. I did lose around the same time frame from a second device.
Below are the logs from slightly before through during the loss of data.
Aug 1 04:53:24 vultr kernel: [31132.150691] [UFW BLOCK] IN=enp1s0 OUT= MAC=56:00:04:83:eb:ed:fe:00:04:83:eb:ed:08:00 SRC=103.57.130.82 DST=45.77.159.171 LEN=40 TOS=0x00 PREC=0x00 TTL=242 ID=4161 DF PROTO=TCP SPT=41831 DPT=8201 WINDOW=512 RES=0x00 SYN URGP=0
Aug 1 04:53:25 vultr chirpstack-gateway-bridge[816]: time=“2023-08-01T04:53:25.407351337Z” level=info msg=“integration/mqtt: publishing event” event=stats qos=0 topic=us915_0/gateway/c0ee40ffff2a3a01/event/stats
Aug 1 04:53:25 vultr chirpstack[818]: #033 [2m2023-08-01T04:53:25.409292Z#033[0m #033 [32m INFO#033[0m #033 [2mchirpstack::gateway::backend::mqtt#033[0m#033[2m:#033 [0m Message received from gateway #033 [3mregion_config_id#033[0m#033[2m=#033[0m"us915_0" #033 [3mtopic#033[0m#033[2m=#033[0m"us915_0/gateway/c0ee40ffff2a3a01/event/stats" #033 [3mqos#033[0m#033[2m=#033[0m0 #033 [3mjson#033[0m#033[2m=#033[0mfalse
Aug 1 04:53:25 vultr chirpstack[818]: #033 [2m2023-08-01T04:53:25.411534Z#033[0m #033 [32m INFO#033[0m #033 [1mstats#033[0m#033[1m{#033 [0m#033[3mgateway_id#033[0m#033[2m=#033[0mc0ee40ffff2a3a01#033[1m}#033 [0m#033[2m:#033 [0m #033 [2mchirpstack::storage::gateway#033[0m#033[2m:#033 [0m Gateway state updated #033 [3mgateway_id#033[0m#033[2m=#033[0mc0ee40ffff2a3a01
Aug 1 04:53:25 vultr chirpstack[818]: #033 [2m2023-08-01T04:53:25.412280Z#033[0m #033 [32m INFO#033[0m #033 [1mstats#033[0m#033[1m{#033 [0m#033[3mgateway_id#033[0m#033[2m=#033[0mc0ee40ffff2a3a01#033[1m}#033 [0m#033[2m:#033 [0m #033 [2mchirpstack::storage::metrics#033[0m#033[2m:#033 [0m Metrics saved #033 [3mname#033[0m#033[2m=#033[0mgw:c0ee40ffff2a3a01 #033 [3maggregation#033[0m#033[2m=#033[0mHOUR
Aug 1 04:53:25 vultr chirpstack[818]: #033 [2m2023-08-01T04:53:25.412856Z#033[0m #033 [32m INFO#033[0m #033 [1mstats#033[0m#033[1m{#033 [0m#033[3mgateway_id#033[0m#033[2m=#033[0mc0ee40ffff2a3a01#033[1m}#033 [0m#033[2m:#033 [0m #033 [2mchirpstack::storage::metrics#033[0m#033[2m:#033 [0m Metrics saved #033 [3mname#033[0m#033[2m=#033[0mgw:c0ee40ffff2a3a01 #033 [3maggregation#033[0m#033[2m=#033[0mDAY
Aug 1 04:53:25 vultr chirpstack[818]: #033 [2m2023-08-01T04:53:25.413347Z#033[0m #033 [32m INFO#033[0m #033 [1mstats#033[0m#033[1m{#033 [0m#033[3mgateway_id#033[0m#033[2m=#033[0mc0ee40ffff2a3a01#033[1m}#033 [0m#033[2m:#033 [0m #033 [2mchirpstack::storage::metrics#033[0m#033[2m:#033 [0m Metrics saved #033 [3mname#033[0m#033[2m=#033[0mgw:c0ee40ffff2a3a01 #033 [3maggregation#033[0m#033[2m=#033[0mMONTH
Aug 1 04:53:44 vultr kernel: [31152.129783] [UFW BLOCK] IN=enp1s0 OUT= MAC=56:00:04:83:eb:ed:fe:00:04:83:eb:ed:08:00 SRC=103.57.130.82 DST=45.77.159.171 LEN=40 TOS=0x00 PREC=0x00 TTL=242 ID=8781 DF PROTO=TCP SPT=40709 DPT=40324 WINDOW=512 RES=0x00 SYN URGP=0
Aug 1 04:53:55 vultr chirpstack-gateway-bridge[816]: time=“2023-08-01T04:53:55.41921982Z” level=info msg=“integration/mqtt: publishing event” event=stats qos=0 topic=us915_0/gateway/c0ee40ffff2a3a01/event/stats
Aug 1 04:53:55 vultr chirpstack[818]: #033 [2m2023-08-01T04:53:55.421145Z#033[0m #033 [32m INFO#033[0m #033 [2mchirpstack::gateway::backend::mqtt#033[0m#033[2m:#033 [0m Message received from gateway #033 [3mregion_config_id#033[0m#033[2m=#033[0m"us915_0" #033 [3mtopic#033[0m#033[2m=#033[0m"us915_0/gateway/c0ee40ffff2a3a01/event/stats" #033 [3mqos#033[0m#033[2m=#033[0m0 #033 [3mjson#033[0m#033[2m=#033[0mfalse
Aug 1 04:53:55 vultr chirpstack[818]: #033 [2m2023-08-01T04:53:55.423764Z#033[0m #033 [32m INFO#033[0m #033 [1mstats#033[0m#033[1m{#033 [0m#033[3mgateway_id#033[0m#033[2m=#033[0mc0ee40ffff2a3a01#033[1m}#033 [0m#033[2m:#033 [0m #033 [2mchirpstack::storage::gateway#033[0m#033[2m:#033 [0m Gateway state updated #033 [3mgateway_id#033[0m#033[2m=#033[0mc0ee40ffff2a3a01
Aug 1 04:53:55 vultr chirpstack[818]: #033 [2m2023-08-01T04:53:55.424530Z#033[0m #033 [32m INFO#033[0m #033 [1mstats#033[0m#033[1m{#033 [0m#033[3mgateway_id#033[0m#033[2m=#033[0mc0ee40ffff2a3a01#033[1m}#033 [0m#033[2m:#033 [0m #033 [2mchirpstack::storage::metrics#033[0m#033[2m:#033 [0m Metrics saved #033 [3mname#033[0m#033[2m=#033[0mgw:c0ee40ffff2a3a01 #033 [3maggregation#033[0m#033[2m=#033[0mHOUR
Aug 1 04:53:55 vultr chirpstack[818]: #033 [2m2023-08-01T04:53:55.425071Z#033[0m #033 [32m INFO#033[0m #033 [1mstats#033[0m#033[1m{#033 [0m#033[3mgateway_id#033[0m#033[2m=#033[0mc0ee40ffff2a3a01#033[1m}#033 [0m#033[2m:#033 [0m #033 [2mchirpstack::storage::metrics#033[0m#033[2m:#033 [0m Metrics saved #033 [3mname#033[0m#033[2m=#033[0mgw:c0ee40ffff2a3a01 #033 [3maggregation#033[0m#033[2m=#033[0mDAY
Aug 1 04:53:55 vultr chirpstack[818]: #033 [2m2023-08-01T04:53:55.425586Z#033[0m #033 [32m INFO#033[0m #033 [1mstats#033[0m#033[1m{#033 [0m#033[3mgateway_id#033[0m#033[2m=#033[0mc0ee40ffff2a3a01#033[1m}#033 [0m#033[2m:#033 [0m #033 [2mchirpstack::storage::metrics#033[0m#033[2m:#033 [0m Metrics saved #033 [3mname#033[0m#033[2m=#033[0mgw:c0ee40ffff2a3a01 #033 [3maggregation#033[0m#033[2m=#033[0mMONTH
Aug 1 04:54:04 vultr kernel: [31172.395753] [UFW BLOCK] IN=enp1s0 OUT= MAC=56:00:04:83:eb:ed:fe:00:04:83:eb:ed:08:00 SRC=185.81.68.37 DST=45.77.159.171 LEN=52 TOS=0x02 PREC=0x00 TTL=122 ID=2648 DF PROTO=TCP SPT=60287 DPT=3389 WINDOW=8192 RES=0x00 CWR ECE SYN URGP=0
Aug 1 04:54:13 vultr systemd[1]: Starting Daily apt download activities…
Aug 1 04:54:14 vultr systemd[1]: Starting Update APT News…
Aug 1 04:54:14 vultr systemd[1]: Starting Update the local ESM caches…
Aug 1 04:54:15 vultr systemd[1]: apt-news.service: Deactivated successfully.
Aug 1 04:54:15 vultr systemd[1]: Finished Update APT News.
Aug 1 04:54:15 vultr systemd[1]: esm-cache.service: Deactivated successfully.
Aug 1 04:54:15 vultr systemd[1]: Finished Update the local ESM caches.
Aug 1 04:54:18 vultr dbus-daemon[821]: [system] Activating via systemd: service name=‘org.freedesktop.PackageKit’ unit=‘packagekit.service’ requested by ‘:1.18’ (uid=0 pid=4687 comm=“/usr/bin/gdbus call --system --dest org.freedeskto” label=“unconfined”)
Aug 1 04:54:18 vultr systemd[1]: Starting PackageKit Daemon…
Aug 1 04:54:18 vultr PackageKit: daemon start
Aug 1 04:54:19 vultr dbus-daemon[821]: [system] Successfully activated service ‘org.freedesktop.PackageKit’
Aug 1 04:54:19 vultr systemd[1]: Started PackageKit Daemon.
Aug 1 04:54:24 vultr kernel: [31192.007031] [UFW BLOCK] IN=enp1s0 OUT= MAC=56:00:04:83:eb:ed:fe:00:04:83:eb:ed:08:00 SRC=103.57.130.82 DST=45.77.159.171 LEN=40 TOS=0x00 PREC=0x00 TTL=242 ID=26164 DF PROTO=TCP SPT=41831 DPT=8250 WINDOW=512 RES=0x00 SYN URGP=0
Aug 1 04:54:25 vultr chirpstack-gateway-bridge[816]: time=“2023-08-01T04:54:25.423351975Z” level=info msg=“integration/mqtt: publishing event” event=stats qos=0 topic=us915_0/gateway/c0ee40ffff2a3a01/event/stats
Aug 1 04:54:25 vultr chirpstack[818]: #033 [2m2023-08-01T04:54:25.425219Z#033[0m #033 [32m INFO#033[0m #033 [2mchirpstack::gateway::backend::mqtt#033[0m#033[2m:#033 [0m Message received from gateway #033 [3mregion_config_id#033[0m#033[2m=#033[0m"us915_0" #033 [3mtopic#033[0m#033[2m=#033[0m"us915_0/gateway/c0ee40ffff2a3a01/event/stats" #033 [3mqos#033[0m#033[2m=#033[0m0 #033 [3mjson#033[0m#033[2m=#033[0mfalse
Aug 1 04:54:25 vultr chirpstack[818]: #033 [2m2023-08-01T04:54:25.428249Z#033[0m #033 [32m INFO#033[0m #033 [1mstats#033[0m#033[1m{#033 [0m#033[3mgateway_id#033[0m#033[2m=#033[0mc0ee40ffff2a3a01#033[1m}#033 [0m#033[2m:#033 [0m #033 [2mchirpstack::storage::gateway#033[0m#033[2m:#033 [0m Gateway state updated #033 [3mgateway_id#033[0m#033[2m=#033[0mc0ee40ffff2a3a01
Aug 1 04:54:25 vultr chirpstack[818]: #033 [2m2023-08-01T04:54:25.428757Z#033[0m #033 [32m INFO#033[0m #033 [1mstats#033[0m#033[1m{#033 [0m#033[3mgateway_id#033[0m#033[2m=#033[0mc0ee40ffff2a3a01#033[1m}#033 [0m#033[2m:#033 [0m #033 [2mchirpstack::storage::metrics#033[0m#033[2m:#033 [0m Metrics saved #033 [3mname#033[0m#033[2m=#033[0mgw:c0ee40ffff2a3a01 #033 [3maggregation#033[0m#033[2m=#033[0mHOUR
Aug 1 04:54:25 vultr chirpstack[818]: #033 [2m2023-08-01T04:54:25.429086Z#033[0m #033 [32m INFO#033[0m #033 [1mstats#033[0m#033[1m{#033 [0m#033[3mgateway_id#033[0m#033[2m=#033[0mc0ee40ffff2a3a01#033[1m}#033 [0m#033[2m:#033 [0m #033 [2mchirpstack::storage::metrics#033[0m#033[2m:#033 [0m Metrics saved #033 [3mname#033[0m#033[2m=#033[0mgw:c0ee40ffff2a3a01 #033 [3maggregation#033[0m#033[2m=#033[0mDAY
Aug 1 04:54:25 vultr chirpstack[818]: #033 [2m2023-08-01T04:54:25.429654Z#033[0m #033 [32m INFO#033[0m #033 [1mstats#033[0m#033[1m{#033 [0m#033[3mgateway_id#033[0m#033[2m=#033[0mc0ee40ffff2a3a01#033[1m}#033 [0m#033[2m:#033 [0m #033 [2mchirpstack::storage::metrics#033[0m#033[2m:#033 [0m Metrics saved #033 [3mname#033[0m#033[2m=#033[0mgw:c0ee40ffff2a3a01 #033 [3maggregation#033[0m#033[2m=#033[0mMONTH
Aug 1 04:54:44 vultr kernel: [31212.042326] [UFW BLOCK] IN=enp1s0 OUT= MAC=56:00:04:83:eb:ed:fe:00:04:83:eb:ed:08:00 SRC=103.57.130.82 DST=45.77.159.171 LEN=40 TOS=0x00 PREC=0x00 TTL=242 ID=14098 DF PROTO=TCP SPT=40709 DPT=40373 WINDOW=512 RES=0x00 SYN URGP=0
Aug 1 04:54:46 vultr systemd[1]: apt-daily.service: Deactivated successfully.
Aug 1 04:54:46 vultr systemd[1]: Finished Daily apt download activities.
Aug 1 04:54:46 vultr systemd[1]: apt-daily.service: Consumed 29.879s CPU time.
Aug 1 04:54:55 vultr chirpstack-gateway-bridge[816]: time=“2023-08-01T04:54:55.45222711Z” level=info msg=“integration/mqtt: publishing event” event=stats qos=0 topic=us915_0/gateway/c0ee40ffff2a3a01/event/stats
Aug 1 04:54:55 vultr chirpstack[818]: #033 [2m2023-08-01T04:54:55.455427Z#033[0m #033 [32m INFO#033[0m #033 [2mchirpstack::gateway::backend::mqtt#033[0m#033[2m:#033 [0m Message received from gateway #033 [3mregion_config_id#033[0m#033[2m=#033[0m"us915_0" #033 [3mtopic#033[0m#033[2m=#033[0m"us915_0/gateway/c0ee40ffff2a3a01/event/stats" #033 [3mqos#033[0m#033[2m=#033[0m0 #033 [3mjson#033[0m#033[2m=#033[0mfalse
Aug 1 04:54:55 vultr chirpstack[818]: #033 [2m2023-08-01T04:54:55.459541Z#033[0m #033 [32m INFO#033[0m #033 [1mstats#033[0m#033[1m{#033 [0m#033[3mgateway_id#033[0m#033[2m=#033[0mc0ee40ffff2a3a01#033[1m}#033 [0m#033[2m:#033 [0m #033 [2mchirpstack::storage::gateway#033[0m#033[2m:#033 [0m Gateway state updated #033 [3mgateway_id#033[0m#033[2m=#033[0mc0ee40ffff2a3a01
Aug 1 04:54:55 vultr chirpstack[818]: #033 [2m2023-08-01T04:54:55.460097Z#033[0m #033 [32m INFO#033[0m #033 [1mstats#033[0m#033[1m{#033 [0m#033[3mgateway_id#033[0m#033[2m=#033[0mc0ee40ffff2a3a01#033[1m}#033 [0m#033[2m:#033 [0m #033 [2mchirpstack::storage::metrics#033[0m#033[2m:#033 [0m Metrics saved #033 [3mname#033[0m#033[2m=#033[0mgw:c0ee40ffff2a3a01 #033 [3maggregation#033[0m#033[2m=#033[0mHOUR
Aug 1 04:54:55 vultr chirpstack[818]: #033 [2m2023-08-01T04:54:55.460576Z#033[0m #033 [32m INFO#033[0m #033 [1mstats#033[0m#033[1m{#033 [0m#033[3mgateway_id#033[0m#033[2m=#033[0mc0ee40ffff2a3a01#033[1m}#033 [0m#033[2m:#033 [0m #033 [2mchirpstack::storage::metrics#033[0m#033[2m:#033 [0m Metrics saved #033 [3mname#033[0m#033[2m=#033[0mgw:c0ee40ffff2a3a01 #033 [3maggregation#033[0m#033[2m=#033[0mDAY
Aug 1 04:54:55 vultr chirpstack[818]: #033 [2m2023-08-01T04:54:55.461137Z#033[0m #033 [32m INFO#033[0m #033 [1mstats#033[0m#033[1m{#033 [0m#033[3mgateway_id#033[0m#033[2m=#033[0mc0ee40ffff2a3a01#033[1m}#033 [0m#033[2m:#033 [0m #033 [2mchirpstack::storage::metrics#033[0m#033[2m:#033 [0m Metrics saved #033 [3mname#033[0m#033[2m=#033[0mgw:c0ee40ffff2a3a01 #033 [3maggregation#033[0m#033[2m=#033[0mMONTH
Aug 1 04:55:01 vultr CRON[4794]: (root) CMD (command -v debian-sa1 > /dev/null && debian-sa1 1 1)
Aug 1 04:55:04 vultr kernel: [31232.154669] [UFW BLOCK] IN=enp1s0 OUT= MAC=56:00:04:83:eb:ed:fe:00:04:83:eb:ed:08:00 SRC=143.42.1.189 DST=45.77.159.171 LEN=44 TOS=0x00 PREC=0x00 TTL=247 ID=54321 PROTO=TCP SPT=50717 DPT=34567 WINDOW=65535 RES=0x00 SYN URGP=0
Aug 1 04:55:24 vultr kernel: [31252.307802] [UFW BLOCK] IN=enp1s0 OUT= MAC=56:00:04:83:eb:ed:fe:00:04:83:eb:ed:08:00 SRC=103.57.130.82 DST=45.77.159.171 LEN=40 TOS=0x00 PREC=0x00 TTL=242 ID=62517 DF PROTO=TCP SPT=40709 DPT=40406 WINDOW=512 RES=0x00 SYN URGP=0
Aug 1 04:55:25 vultr chirpstack-gateway-bridge[816]: time=“2023-08-01T04:55:25.455154847Z” level=info msg=“integration/mqtt: publishing event” event=stats qos=0 topic=us915_0/gateway/c0ee40ffff2a3a01/event/stats
Aug 1 04:55:25 vultr chirpstack[818]: #033 [2m2023-08-01T04:55:25.456654Z#033[0m #033 [32m INFO#033[0m #033 [2mchirpstack::gateway::backend::mqtt#033[0m#033[2m:#033 [0m Message received from gateway #033 [3mregion_config_id#033[0m#033[2m=#033[0m"us915_0" #033 [3mtopic#033[0m#033[2m=#033[0m"us915_0/gateway/c0ee40ffff2a3a01/event/stats" #033 [3mqos#033[0m#033[2m=#033[0m0 #033 [3mjson#033[0m#033[2m=#033[0mfalse
Aug 1 04:55:25 vultr chirpstack[818]: #033 [2m2023-08-01T04:55:25.458697Z#033[0m #033 [32m INFO#033[0m #033 [1mstats#033[0m#033[1m{#033 [0m#033[3mgateway_id#033[0m#033[2m=#033[0mc0ee40ffff2a3a01#033[1m}#033 [0m#033[2m:#033 [0m #033 [2mchirpstack::storage::gateway#033[0m#033[2m:#033 [0m Gateway state updated #033 [3mgateway_id#033[0m#033[2m=#033[0mc0ee40ffff2a3a01
Aug 1 04:55:25 vultr chirpstack[818]: #033 [2m2023-08-01T04:55:25.459379Z#033[0m #033 [32m INFO#033[0m #033 [1mstats#033[0m#033[1m{#033 [0m#033[3mgateway_id#033[0m#033[2m=#033[0mc0ee40ffff2a3a01#033[1m}#033 [0m#033[2m:#033 [0m #033 [2mchirpstack::storage::metrics#033[0m#033[2m:#033 [0m Metrics saved #033 [3mname#033[0m#033[2m=#033[0mgw:c0ee40ffff2a3a01 #033 [3maggregation#033[0m#033[2m=#033[0mHOUR
Aug 1 04:55:25 vultr chirpstack[818]: #033 [2m2023-08-01T04:55:25.459926Z#033[0m #033 [32m INFO#033[0m #033 [1mstats#033[0m#033[1m{#033 [0m#033[3mgateway_id#033[0m#033[2m=#033[0mc0ee40ffff2a3a01#033[1m}#033 [0m#033[2m:#033 [0m #033 [2mchirpstack::storage::metrics#033[0m#033[2m:#033 [0m Metrics saved #033 [3mname#033[0m#033[2m=#033[0mgw:c0ee40ffff2a3a01 #033 [3maggregation#033[0m#033[2m=#033[0mDAY
Aug 1 04:55:25 vultr chirpstack[818]: #033 [2m2023-08-01T04:55:25.460372Z#033[0m #033 [32m INFO#033[0m #033 [1mstats#033[0m#033[1m{#033 [0m#033[3mgateway_id#033[0m#033[2m=#033[0mc0ee40ffff2a3a01#033[1m}#033 [0m#033[2m:#033 [0m #033 [2mchirpstack::storage::metrics#033[0m#033[2m:#033 [0m Metrics saved #033 [3mname#033[0m#033[2m=#033[0mgw:c0ee40ffff2a3a01 #033 [3maggregation#033[0m#033[2m=#033[0mMONTH
Aug 1 04:55:44 vultr kernel: [31272.545381] [UFW BLOCK] IN=enp1s0 OUT= MAC=56:00:04:83:eb:ed:fe:00:04:83:eb:ed:08:00 SRC=103.57.130.82 DST=45.77.159.171 LEN=40 TOS=0x00 PREC=0x00 TTL=242 ID=40537 DF PROTO=TCP SPT=41831 DPT=8316 WINDOW=512 RES=0x00 SYN URGP=0
Aug 1 04:55:55 vultr chirpstack-gateway-bridge[816]: time=“2023-08-01T04:55:55.46712714Z” level=info msg=“integration/mqtt: publishing event” event=stats qos=0 topic=us915_0/gateway/c0ee40ffff2a3a01/event/stats
Aug 1 04:55:55 vultr chirpstack[818]: #033 [2m2023-08-01T04:55:55.469092Z#033[0m #033 [32m INFO#033[0m #033 [2mchirpstack::gateway::backend::mqtt#033[0m#033[2m:#033 [0m Message received from gateway #033 [3mregion_config_id#033[0m#033[2m=#033[0m"us915_0" #033 [3mtopic#033[0m#033[2m=#033[0m"us915_0/gateway/c0ee40ffff2a3a01/event/stats" #033 [3mqos#033[0m#033[2m=#033[0m0 #033 [3mjson#033[0m#033[2m=#033[0mfalse
Aug 1 04:55:55 vultr chirpstack[818]: #033 [2m2023-08-01T04:55:55.471105Z#033[0m #033 [32m INFO#033[0m #033 [1mstats#033[0m#033[1m{#033 [0m#033[3mgateway_id#033[0m#033[2m=#033[0mc0ee40ffff2a3a01#033[1m}#033 [0m#033[2m:#033 [0m #033 [2mchirpstack::storage::gateway#033[0m#033[2m:#033 [0m Gateway state updated #033 [3mgateway_id#033[0m#033[2m=#033[0mc0ee40ffff2a3a01
Aug 1 04:55:55 vultr chirpstack[818]: #033 [2m2023-08-01T04:55:55.471730Z#033[0m #033 [32m INFO#033[0m #033 [1mstats#033[0m#033[1m{#033 [0m#033[3mgateway_id#033[0m#033[2m=#033[0mc0ee40ffff2a3a01#033[1m}#033 [0m#033[2m:#033 [0m #033 [2mchirpstack::storage::metrics#033[0m#033[2m:#033 [0m Metrics saved #033 [3mname#033[0m#033[2m=#033[0mgw:c0ee40ffff2a3a01 #033 [3maggregation#033[0m#033[2m=#033[0mHOUR
Aug 1 04:55:55 vultr chirpstack[818]: #033 [2m2023-08-01T04:55:55.472213Z#033[0m #033 [32m INFO#033[0m #033 [1mstats#033[0m#033[1m{#033 [0m#033[3mgateway_id#033[0m#033[2m=#033[0mc0ee40ffff2a3a01#033[1m}#033 [0m#033[2m:#033 [0m #033 [2mchirpstack::storage::metrics#033[0m#033[2m:#033 [0m Metrics saved #033 [3mname#033[0m#033[2m=#033[0mgw:c0ee40ffff2a3a01 #033 [3maggregation#033[0m#033[2m=#033[0mDAY
Aug 1 04:55:55 vultr chirpstack[818]: #033 [2m2023-08-01T04:55:55.472667Z#033[0m #033 [32m INFO#033[0m #033 [1mstats#033[0m#033[1m{#033 [0m#033[3mgateway_id#033[0m#033[2m=#033[0mc0ee40ffff2a3a01#033[1m}#033 [0m#033[2m:#033 [0m #033 [2mchirpstack::storage::metrics#033[0m#033[2m:#033 [0m Metrics saved #033 [3mname#033[0m#033[2m=#033[0mgw:c0ee40ffff2a3a01 #033 [3maggregation#033[0m#033[2m=#033[0mMONTH
Aug 1 04:56:04 vultr kernel: [31292.137866] [UFW BLOCK] IN=enp1s0 OUT= MAC=56:00:04:83:eb:ed:fe:00:04:83:eb:ed:08:00 SRC=103.57.130.82 DST=45.77.159.171 LEN=40 TOS=0x00 PREC=0x00 TTL=242 ID=14180 DF PROTO=TCP SPT=41831 DPT=8332 WINDOW=512 RES=0x00 SYN URGP=0
Aug 1 04:56:24 vultr kernel: [31312.180039] [UFW BLOCK] IN=enp1s0 OUT= MAC=56:00:04:83:eb:ed:fe:00:04:83:eb:ed:08:00 SRC=103.57.130.82 DST=45.77.159.171 LEN=40 TOS=0x00 PREC=0x00 TTL=242 ID=35081 DF PROTO=TCP SPT=40709 DPT=40455 WINDOW=512 RES=0x00 SYN URGP=0
Aug 1 04:56:44 vultr kernel: [31332.409202] [UFW BLOCK] IN=enp1s0 OUT= MAC=56:00:04:83:eb:ed:fe:00:04:83:eb:ed:08:00 SRC=103.57.130.82 DST=45.77.159.171 LEN=40 TOS=0x00 PREC=0x00 TTL=242 ID=45880 DF PROTO=TCP SPT=41831 DPT=8365 WINDOW=512 RES=0x00 SYN URGP=0
Aug 1 04:57:04 vultr kernel: [31352.402599] [UFW BLOCK] IN=enp1s0 OUT= MAC=56:00:04:83:eb:ed:fe:00:04:83:eb:ed:08:00 SRC=103.57.130.82 DST=45.77.159.171 LEN=40 TOS=0x00 PREC=0x00 TTL=242 ID=50515 DF PROTO=TCP SPT=40709 DPT=40488 WINDOW=512 RES=0x00 SYN URGP=0
Aug 1 04:57:24 vultr kernel: [31372.548546] [UFW BLOCK] IN=enp1s0 OUT= MAC=56:00:04:83:eb:ed:fe:00:04:83:eb:ed:08:00 SRC=5.8.18.45 DST=45.77.159.171 LEN=40 TOS=0x00 PREC=0x00 TTL=245 ID=37950 PROTO=TCP SPT=41383 DPT=64718 WINDOW=1024 RES=0x00 SYN URGP=0
Aug 1 04:57:44 vultr kernel: [31392.115026] [UFW BLOCK] IN=enp1s0 OUT= MAC=56:00:04:83:eb:ed:fe:00:04:83:eb:ed:08:00 SRC=103.57.130.82 DST=45.77.159.171 LEN=40 TOS=0x00 PREC=0x00 TTL=242 ID=2121 DF PROTO=TCP SPT=41831 DPT=8414 WINDOW=512 RES=0x00 SYN URGP=0
Aug 1 04:57:48 vultr chirpstack-gateway-bridge[816]: time=“2023-08-01T04:57:48.552552179Z” level=info msg=“integration/mqtt: unsubscribing from topic” topic=“us915_0/gateway/c0ee40ffff2a3a01/command/#”
Aug 1 04:57:48 vultr chirpstack-gateway-bridge[816]: time=“2023-08-01T04:57:48.555670525Z” level=warning msg=“[store] memorystore del: message 2 not found” module=mqtt
Aug 1 04:57:48 vultr chirpstack-gateway-bridge[816]: time=“2023-08-01T04:57:48.5569525Z” level=info msg=“integration/mqtt: publishing state” gateway_id=c0ee40ffff2a3a01 qos=0 state=conn topic=gateway/c0ee40ffff2a3a01/state/conn
Aug 1 04:58:04 vultr kernel: [31412.111999] [UFW BLOCK] IN=enp1s0 OUT= MAC=56:00:04:83:eb:ed:fe:00:04:83:eb:ed:08:00 SRC=103.57.130.82 DST=45.77.159.171 LEN=40 TOS=0x00 PREC=0x00 TTL=242 ID=55861 DF PROTO=TCP SPT=40709 DPT=40537 WINDOW=512 RES=0x00 SYN URGP=0
Aug 1 04:58:24 vultr kernel: [31432.422905] [UFW BLOCK] IN=enp1s0 OUT= MAC=56:00:04:83:eb:ed:fe:00:04:83:eb:ed:08:00 SRC=103.57.130.82 DST=45.77.159.171 LEN=40 TOS=0x00 PREC=0x00 TTL=242 ID=1092 DF PROTO=TCP SPT=41831 DPT=8447 WINDOW=512 RES=0x00 SYN URGP=0
Aug 1 04:58:44 vultr kernel: [31451.998307] [UFW BLOCK] IN=enp1s0 OUT= MAC=56:00:04:83:eb:ed:fe:00:04:83:eb:ed:08:00 SRC=103.57.130.82 DST=45.77.159.171 LEN=40 TOS=0x00 PREC=0x00 TTL=242 ID=40458 DF PROTO=TCP SPT=41831 DPT=8463 WINDOW=512 RES=0x00 SYN URGP=0
Aug 1 04:59:04 vultr kernel: [31472.581716] [UFW BLOCK] IN=enp1s0 OUT= MAC=56:00:04:83:eb:ed:fe:00:04:83:eb:ed:08:00 SRC=89.248.165.66 DST=45.77.159.171 LEN=40 TOS=0x00 PREC=0x00 TTL=245 ID=8440 PROTO=TCP SPT=46118 DPT=13710 WINDOW=1024 RES=0x00 SYN URGP=0
Aug 1 04:59:24 vultr kernel: [31492.274030] [UFW BLOCK] IN=enp1s0 OUT= MAC=56:00:04:83:eb:ed:fe:00:04:83:eb:ed:08:00 SRC=103.57.130.82 DST=45.77.159.171 LEN=40 TOS=0x00 PREC=0x00 TTL=242 ID=55906 DF PROTO=TCP SPT=41831 DPT=8496 WINDOW=512 RES=0x00 SYN URGP=0
Aug 1 04:59:44 vultr kernel: [31512.147331] [UFW BLOCK] IN=enp1s0 OUT= MAC=56:00:04:83:eb:ed:fe:00:04:83:eb:ed:08:00 SRC=103.57.130.82 DST=45.77.159.171 LEN=40 TOS=0x00 PREC=0x00 TTL=242 ID=11287 DF PROTO=TCP SPT=40709 DPT=40619 WINDOW=512 RES=0x00 SYN URGP=0
Aug 1 05:00:04 vultr kernel: [31532.556831] [UFW BLOCK] IN=enp1s0 OUT= MAC=56:00:04:83:eb:ed:fe:00:04:83:eb:ed:08:00 SRC=103.57.130.82 DST=45.77.159.171 LEN=40 TOS=0x00 PREC=0x00 TTL=242 ID=22020 DF PROTO=TCP SPT=41831 DPT=8529 WINDOW=512 RES=0x00 SYN URGP=0
Aug 1 05:00:24 vultr kernel: [31552.111496] [UFW BLOCK] IN=enp1s0 OUT= MAC=56:00:04:83:eb:ed:fe:00:04:83:eb:ed:08:00 SRC=103.57.130.82 DST=45.77.159.171 LEN=40 TOS=0x00 PREC=0x00 TTL=242 ID=61234 DF PROTO=TCP SPT=41831 DPT=8545 WINDOW=512 RES=0x00 SYN URGP=0
Aug 1 05:00:44 vultr kernel: [31572.550415] [UFW BLOCK] IN=enp1s0 OUT= MAC=56:00:04:83:eb:ed:fe:00:04:83:eb:ed:08:00 SRC=79.124.49.86 DST=45.77.159.171 LEN=40 TOS=0x00 PREC=0x00 TTL=240 ID=17338 PROTO=TCP SPT=44368 DPT=52267 WINDOW=1024 RES=0x00 SYN URGP=0
Aug 1 05:01:04 vultr kernel: [31592.378266] [UFW BLOCK] IN=enp1s0 OUT= MAC=56:00:04:83:eb:ed:fe:00:04:83:eb:ed:08:00 SRC=103.57.130.82 DST=45.77.159.171 LEN=40 TOS=0x00 PREC=0x00 TTL=242 ID=43825 DF PROTO=TCP SPT=41831 DPT=8578 WINDOW=512 RES=0x00 SYN URGP=0
Aug 1 05:01:24 vultr kernel: [31612.083858] [UFW BLOCK] IN=enp1s0 OUT= MAC=56:00:04:83:eb:ed:fe:00:04:83:eb:ed:08:00 SRC=103.57.130.82 DST=45.77.159.171 LEN=40 TOS=0x00 PREC=0x00 TTL=242 ID=32045 DF PROTO=TCP SPT=40709 DPT=40701 WINDOW=512 RES=0x00 SYN URGP=0
Aug 1 05:01:44 vultr kernel: [31632.620497] [UFW BLOCK] IN=enp1s0 OUT= MAC=56:00:04:83:eb:ed:fe:00:04:83:eb:ed:08:00 SRC=103.57.130.82 DST=45.77.159.171 LEN=40 TOS=0x00 PREC=0x00 TTL=242 ID=42873 DF PROTO=TCP SPT=41831 DPT=8611 WINDOW=512 RES=0x00 SYN URGP=0
Aug 1 05:02:04 vultr kernel: [31652.066221] [UFW BLOCK] IN=enp1s0 OUT= MAC=56:00:04:83:eb:ed:fe:00:04:83:eb:ed:08:00 SRC=103.57.130.82 DST=45.77.159.171 LEN=40 TOS=0x00 PREC=0x00 TTL=242 ID=16656 DF PROTO=TCP SPT=41831 DPT=8627 WINDOW=512 RES=0x00 SYN URGP=0
Aug 1 05:02:24 vultr kernel: [31672.837416] [UFW BLOCK] IN=enp1s0 OUT= MAC=56:00:04:83:eb:ed:fe:00:04:83:eb:ed:08:00 SRC=103.57.130.82 DST=45.77.159.171 LEN=40 TOS=0x00 PREC=0x00 TTL=242 ID=58122 DF PROTO=TCP SPT=41831 DPT=8644 WINDOW=512 RES=0x00 SYN URGP=0
Aug 1 05:02:44 vultr kernel: [31692.236212] [UFW BLOCK] IN=enp1s0 OUT= MAC=56:00:04:83:eb:ed:fe:00:04:83:eb:ed:08:00 SRC=103.57.130.82 DST=45.77.159.171 LEN=40 TOS=0x00 PREC=0x00 TTL=241 ID=32053 DF PROTO=TCP SPT=41831 DPT=8660 WINDOW=512 RES=0x00 SYN URGP=0
Aug 1 05:03:04 vultr kernel: [31712.034780] [UFW BLOCK] IN=enp1s0 OUT= MAC=56:00:04:83:eb:ed:fe:00:04:83:eb:ed:08:00 SRC=103.57.130.82 DST=45.77.159.171 LEN=40 TOS=0x00 PREC=0x00 TTL=241 ID=52856 DF PROTO=TCP SPT=40709 DPT=40783 WINDOW=512 RES=0x00 SYN URGP=0
Aug 1 05:03:24 vultr kernel: [31732.474372] [UFW BLOCK] IN=enp1s0 OUT= MAC=56:00:04:83:eb:ed:fe:00:04:83:eb:ed:08:00 SRC=103.57.130.82 DST=45.77.159.171 LEN=40 TOS=0x00 PREC=0x00 TTL=242 ID=63779 DF PROTO=TCP SPT=41831 DPT=8693 WINDOW=512 RES=0x00 SYN URGP=0
Aug 1 05:03:44 vultr kernel: [31752.111066] [UFW BLOCK] IN=enp1s0 OUT= MAC=56:00:04:83:eb:ed:fe:00:04:83:eb:ed:08:00 SRC=103.57.130.82 DST=45.77.159.171 LEN=40 TOS=0x00 PREC=0x00 TTL=242 ID=37410 DF PROTO=TCP SPT=41831 DPT=8709 WINDOW=512 RES=0x00 SYN URGP=0
Aug 1 05:04:05 vultr kernel: [31773.052086] [UFW BLOCK] IN=enp1s0 OUT= MAC=56:00:04:83:eb:ed:fe:00:04:83:eb:ed:08:00 SRC=103.57.130.82 DST=45.77.159.171 LEN=40 TOS=0x00 PREC=0x00 TTL=242 ID=60763 DF PROTO=TCP SPT=40709 DPT=40833 WINDOW=512 RES=0x00 SYN URGP=0
Aug 1 05:04:12 vultr chirpstack[818]: #033 [2m2023-08-01T05:04:12.264152Z#033[0m #033 [32m INFO#033[0m #033 [1mhttp#033[0m#033[1m{#033 [0m#033[3mmethod#033[0m#033[2m=#033[0m"GET" #033 [3muri#033[0m#033[2m=#033[0m/ #033 [3mversion#033[0m#033[2m=#033[0mHTTP/1.1#033[1m}#033 [0m#033[2m:#033 [0m #033 [2mchirpstack::api#033[0m#033[2m:#033 [0m Finished processing request #033 [3mstatus#033[0m#033[2m=#033[0m"200" #033 [3mlatency#033[0m#033[2m=#033[0m102.673µs
Aug 1 05:04:24 vultr kernel: [31792.445516] [UFW BLOCK] IN=enp1s0 OUT= MAC=56:00:04:83:eb:ed:fe:00:04:83:eb:ed:08:00 SRC=103.57.130.82 DST=45.77.159.171 LEN=40 TOS=0x00 PREC=0x00 TTL=242 ID=20078 DF PROTO=TCP SPT=41831 DPT=8742 WINDOW=512 RES=0x00 SYN URGP=0
I am making the assumption that the UFW has something to do with the failing gateway. The failures are sporadic and mostly happen during the night time.
I don’t think UFW has something to do with that. Sorry to say something obvious, but are you sure that the gateway is not plugged to an automatically commuted plug? Or that the router is not stopping at night hours?
We have this issue regularly in shopping malls, they shut down the power during nights to spare energy…
@Jerome73 I am not losing power as this is my home modem router. I am fine if it is obvious as I am no expert, so I am glad to remove UFW as a potential issue.
The plug is a standard wall outlet. Both the router and gateway are plugged in.
I did disable wifi and switched to ethernet and the gateway seemed to kick back on. Still not sure this is the root cause.
system
Closed
October 30, 2023, 2:45pm
6
