I’m using the full OS installation to try to get this system running.
I have a RPI 3 with a RHF0M301 hat.
When I go through the setup for the concentrator shield and select option 9 Risinghf RHF0M301 and select US915 and the first channel option and then yes to all the file write options, I am returned to the main menu.
At the top it says
Version 3.3.3
Gateway ID: not configured
When I look at the general configuration for Concentratord it shows
model=“generic_us915”
and at the end of the file it shows
reset_pin=0
When I exit to the command line and enter sudo monit summary it tells me everything is OK except the chirpstack-concentratord which has the status of “does not exist”.
Hello, I have exact the same problem with the same hardware and configuration. I checked everything and cant find the reason for this. There is also nopc error message or somtething to see in the logs except a permanent restart of the concentratord service.
When i try to start the chirpstack-concentratord service alone I get at least an error message:
ERROR: Failed to load fw 1
ERROR:Version of callibration firmware not expected, acutal=0 expected:2
Thread ‘main’ panicked at called Result::unwrap() on an ‘Err’ value: ‘lgw_start failed’
My Question is, if model=‘generic_eu868’ in the concentratord is right? Or should there be a model specified, which matches the RHF0M301 specifications? I also tried different reset pin settings like 22 and 7.
