Anyone willing to share their configuration of PI 4 running Chirpstack NS and a EM300-TH from Milesight? I have been trying for 2 days to see this in my PI but no matter the config I try I only see “This device has not (yet) been activated.”
Have you seen these guides:
- Connecting a gateway - ChirpStack open-source LoRaWAN® Network Server documentation
- Connecting a device - ChirpStack open-source LoRaWAN® Network Server documentation
They might help you to debug at which stage there is a problem.
Thank you from the links. I have moved on from ETH300 and to some LoRa sensors I built using RAK3172. I can control and see what they are sending (using serial interface) better than what I could with ETH300. Since I am using Pi4 and 5146 do I need to setup UDP forwarder? I have tried with both with and without and can not see frames in either gateway or in the device. I know the devices work because I can setup and use them on a seperate Milesight Gateway that I have.
Regardless, Thank you for the reply. Hopefully I can get this working. I like the way you have done the OS.
**EDIT: I did not realize I had to setup the MQTT forwarder for the OS to work! Once I did that eveything started showing up. I still don’t know how to setup the GPS attached to the 5146 but will continue testing to find out. Thank you for replying to the topic, I had almost given up on it and was looking for a new solution for my project. Now back to learning more and implementing. Refining etc. Thank you again.
