Gateway full image is F***ed.
chirpstack-concentratord Initializing then fails with no config.
Chirpstack Gateway Config --> Select Setup Copncentrator Shield --> RAK2245 --> AU915
Prompt to overwrite --> Yes
FAILS WITH ERRORS
/usr/bin/gateway-config: line 343: [: missing `]’
cp: can’t stat ‘/etc/chirpstack-concentratord/sx1301/examples/as923.toml’: No such file or directory
cp: can’t stat ‘/etc/chirpstack-concentratord/sx1301/examples/as923_0.toml’: No such file or directory
2: eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc mq state UP mode DEFAULT group default qlen 1000
link/ether dc:a6:32:36:ab:51 brd ff:ff:ff:ff:ff:ff
Config creation script fails.
I manually created the config files.
Concentrator now starts.
New problems is cannot add network server via application server admin interface.
Error:
context deadline exceeded (code: 2)
Now getting “Failed to fetch”
Please note that this is a community forum where we try to be as helpful as we can. This however does not really invite others to help you.
I can not find any version information from your post. In case you are experiencing an issue with the latest version, please create an issue here with all the information that is needed to reproduce the issue so that I can look into this: Issues · chirpstack/chirpstack-gateway-os · GitHub.
