RaspberryPi + IC880A-SPI: No Connection - Questions about Pin Configurations
Hello together, I need some help understanding how to get the IC880A running with the Full Chirpstack OS.
What I have done:
Followed Getting started - ChirpStack open-source LoRaWAN® Network Server documentation until and including “Configure Concentratord”.
HW is connected following Building a gateway with Raspberry Pi and IC880A | The Things Stack for LoRaWAN and https://www.instructables.com/Raspberry-Pi-LoRaWAN-Gateway/
What do I see:
Using logread: This in a loop every 5 seconds
Sat May 11 10:22:40 2024 user.info chirpstack-concentratord-sx1301[16605]: Configuring reset pin, dev: /dev/gpiochip0, pin: 5
Sat May 11 10:22:40 2024 user.info chirpstack-concentratord-sx1301[16605]: Starting Concentratord SX1301 (version: 4.3.5, docs: https://www.chirpstack.io/docs/chirpstack-concentratord/)
Sat May 11 10:22:40 2024 user.info chirpstack-concentratord-sx1301[16605]: Triggering sx1302 reset
Sat May 11 10:22:40 2024 user.info chirpstack-concentratord-sx1301[16605]: Setting spi device path, spidev_path: /dev/spidev0.0
Sat May 11 10:22:40 2024 user.info chirpstack-concentratord-sx1301[16605]: Setting board configuration, lorawan_public: true, clock_source: 1
Sat May 11 10:22:40 2024 user.info chirpstack-concentratord-sx1301[16605]: Setting up concentrator radios
Sat May 11 10:22:40 2024 user.info chirpstack-concentratord-sx1301[16605]: Configuring radio, radio: 0, enabled: true, center_freq: 867500000, type: SX1257
Sat May 11 10:22:40 2024 user.info chirpstack-concentratord-sx1301[16605]: Configuring radio, radio: 1, enabled: true, center_freq: 868500000, type: SX1257
Sat May 11 10:22:40 2024 user.info chirpstack-concentratord-sx1301[16605]: Setting up concentrator channels
Sat May 11 10:22:40 2024 user.info chirpstack-concentratord-sx1301[16605]: Configuring multi-SF LoRa channel, channel: 0, enabled: true, freq: 868100000, rf_chain: 1, if_freq: -400000
Sat May 11 10:22:40 2024 user.info chirpstack-concentratord-sx1301[16605]: Configuring multi-SF LoRa channel, channel: 1, enabled: true, freq: 868300000, rf_chain: 1, if_freq: -200000
Sat May 11 10:22:40 2024 user.info chirpstack-concentratord-sx1301[16605]: Configuring multi-SF LoRa channel, channel: 2, enabled: true, freq: 868500000, rf_chain: 1, if_freq: 0
Sat May 11 10:22:40 2024 user.info chirpstack-concentratord-sx1301[16605]: Configuring multi-SF LoRa channel, channel: 3, enabled: true, freq: 867100000, rf_chain: 0, if_freq: -400000
Sat May 11 10:22:40 2024 user.info chirpstack-concentratord-sx1301[16605]: Configuring multi-SF LoRa channel, channel: 4, enabled: true, freq: 867300000, rf_chain: 0, if_freq: -200000
Sat May 11 10:22:40 2024 user.info chirpstack-concentratord-sx1301[16605]: Configuring multi-SF LoRa channel, channel: 5, enabled: true, freq: 867500000, rf_chain: 0, if_freq: 0
Sat May 11 10:22:40 2024 user.info chirpstack-concentratord-sx1301[16605]: Configuring multi-SF LoRa channel, channel: 6, enabled: true, freq: 867700000, rf_chain: 0, if_freq: 200000
Sat May 11 10:22:40 2024 user.info chirpstack-concentratord-sx1301[16605]: Configuring multi-SF LoRa channel, channel: 7, enabled: true, freq: 867900000, rf_chain: 0, if_freq: 400000
Sat May 11 10:22:40 2024 user.info chirpstack-concentratord-sx1301[16605]: Configuring Std LoRa channel, enabled: true, freq: 868300000, rf_chain: 1, if_freq: -200000
Sat May 11 10:22:40 2024 user.info chirpstack-concentratord-sx1301[16605]: Configuring FSK channel, enabled: true, freq: 868800000, rf_chain: 1, if_freq: 300000
Sat May 11 10:22:40 2024 user.info chirpstack-concentratord-sx1301[16605]: Starting the concentrator
Questions:
Is there any documentation on how to modify the reset pin? According to the log above, its using pin 5 as reset pin. But according to the two tutorials regarding I linked above, it should be pin 22.
According to https://github.com/chirpstack/chirpstack-concentratord/issues/11 it should be possible. I added option reset_pin 22 or option sx1301_reset_pin 22 to /etc/config/chirpstack-concentrator without any change in the above log.
Should I be worried, that the log above in the third line it says Triggering sx1302 reset ?
Is there any documentation about the expected pin assignement when using the IC880A? Can someone confirm that the wiring above is correct?
I guess that the communication to the shield is not working, either because of configuriation or wiring issues. Is there any way to get more detailled logs about the communication attempt that would help me debug this issue? The logread is quite high-level. I tried changing the /var/etc/chirpstack-concentratord/concentratord.toml log_level setting. Then I discovered that this is overwritten by /lib/functions/chirpstack-concentrator.sh. However, changing it there, also did not lead to any result.
The printed log was fixed in:
I’m not 100% sure if this is already part of the latest ChirpStack Gateway OS, but configuration for this was added a while back:
For further references, after I lost my progress and ran into the same problem as before:
adding option sx1301_reset_pin '25' to /etc/config/chirpstack-concentratord for config sx1301, it worked. Note, that physical pin 22 on Raspberry 3B+ is referenced as GPIO25
