Reactivate the device using API
Hello
I was going through the chirpstack V3 API documents and found one interesting API.
[/api/devices/{device_activation.dev_eui}/activate]
I also notice even after devices get deactivated due to redis TTL expire and devices become deactivated but we still have all activation parameters in DB in the device_activation table.
So now I will come to the question:
Suppose my device session TTL expires and the device shows deactivated in chirpstack. Can I still reactivate the device(OTAA) using this API, as we all have parameters in the device_activation table?
Thanks
I am not sure I understood correctly. To my understanding this is the same as “disable” on web interface of device > configuration > “device is disabled”
If device disabled or enabled there is no communication between chirpstack and the device. Chirpstack just ignores the device.
I don’t see a problem to re-activate the device. I don’t get what TTL has to do with chirpstack. Because of broken integration, chirpstack disables the device?
Thank you for your response.
Generally, when TTL expires, the redis device becomes deactivated and in device->activation it will have the “This device has not yet been activated.” message.
But what I observed is that session parameters still persisted in the DB in the device_activation table.
So, can we reactivate those devices using API?
Thanks
Yes you can. However, make sure to set the correct frame-counters.
Thank you for the response
I think frame counter also stores in same table?
Should i be using the same value?
Thanks
This topic was automatically closed after 83 days. New replies are no longer allowed.
