Readings from Sensor
As far as I understand, I have to define how chirpstack reads the data received in the LORAWAN message.
The SenseCAP S2103 is reading consistent data locally, and that data is being sent and received correctly.
Yet when defined in Tenants / ChirpStack / Device profiles / Sensor in the “Measurement” tab I am unable to set and visualise the data that data.
Obviously I’m more interested in having that data sent via MQTT, but it’s odd that is not visualised in the dashboard
Attaching screen grab
fo07
Unfortunately pausing that video just brings up the initial thumbnail so it’s hard to get details when you’re going through that quickly.
Looks like the config is correct though, strange that they are not displaying.
How recently did you configure the measurements? Since the graphs are on the 31d possibly the first day just hasn’t come in yet? Have you checked the 24h with the same issue?
Have you updated your Chirpstack to the newest version?
Thanks for the feedback about the animated gif.
It was that, the data is recevied now[1].
yet I’m sending data every 5 minutes [2] (for testing purposes) and is not shown in the graph. But guess is ok
[1]
[2]
Ya I believe Chirpstack averages the graphs. So if you set it to 24h graph the value for the hour will be the average of the 6 uplinks in the hour (I think).
Glad it’s working.
Hello @vg000n @Liam_Philipp I am working on the same sensor but in ASIA region. My gateway is up and upon sending join request, nothing pops up in the docker compose terminal no join request. I have configured the S2103 from mobile app to AS923 and Platform as other platform as chirpstack is not present.
Any help will be appreciated.
Have you configured you MQTT topic prefixes and have as923 as an enabled region in your chirpstack.toml?
Yes, the problem is fixed, the default chirpstack was limited to two channel, I saw logs and added the rest now it is working fine.
