vic
August 2, 2024, 10:29am
1
I cannot connect end devices to Chirpstack server using Basic Station. I see in log file of Basic station “Received ‘dnmsg’ before ‘router_config’ - dropped”, see below:
2024-08-05 16:19:45.119 [S2E:VERB] RX 869.1MHz DR0 SF12/BW125 snr=10.2 rssi=-38 xtime=0x8A000004D16D03 - jreq MHdr=00 JoinEui=7665:6761:7464:3131 DevEui=70b3:d50a:d000:9299 DevNonce=15996 MIC=-1504505488
2024-08-05 16:19:45.391 [S2E:WARN] Received ‘dnmsg’ before ‘router_config’ - dropped
2024-08-05 16:19:57.400 [SYN:VERB] Time sync rejected: quality=355 threshold=233
2024-08-05 16:20:01.600 [SYN:VERB] Time sync rejected: quality=284 threshold=233
2024-08-05 16:20:03.701 [SYN:VERB] Time sync rejected: quality=319 threshold=233
2024-08-05 16:20:07.400 [SYN:INFO] MCU/SX130X drift stats: min: +0.0ppm q50: +5.0ppm q80: +10.6ppm max: -11.7ppm - threshold q90: +11.6ppm
2024-08-05 16:20:07.400 [SYN:INFO] Mean MCU drift vs SX130X#0: 3.8ppm
2024-08-05 16:20:10.600 [SYN:INFO] PPS/SX130X drift stats: min: +0.0ppm q50: +0.0ppm q80: +0.0ppm max: -0.3ppm - threshold q80: +0.0ppm
2024-08-05 16:20:40.600 [SYN:VERB] Time sync rejected: quality=276 threshold=233
2024-08-05 16:20:42.701 [SYN:VERB] Time sync rejected: quality=374 threshold=233
2024-08-05 16:20:44.802 [SYN:VERB] Time sync rejected: quality=847 threshold=233
2024-08-05 16:20:46.903 [SYN:INFO] Time sync qualities: min=149 q90=355 max=847 (previous q90=233)
2024-08-05 16:20:54.989 [S2E:VERB] RX 868.9MHz DR0 SF12/BW125 snr=12.5 rssi=-41 xtime=0x8A000008FB80F2 - jreq MHdr=00 JoinEui=a840:4100:0:101 DevEui=a840:4158:e189:3882 DevNonce=38262 MIC=1907188019
2024-08-05 16:20:55.250 [S2E:WARN] Received ‘dnmsg’ before ‘router_config’ - dropped
Where need I look for the reason: in Basic Station or in Chirpstack server?
Can anyone give me the working example of the station.conf and chirpstack-gateway-bridge.toml as example for SX1302 HAT on Raspberry Pi?
Thank you!
Thia is due to region not being set as AS923 was not recognized. This was solved in another thread though.
Are you still seeing issues?
vic
August 20, 2024, 6:09am
3
Yes, you are right. The reason is my region RU864 is not presented in source code of Semtech Basic Station. I have added that region as it was written in this comment: Received 'dnmsg' before 'router_config' - dropped · Issue #200 · lorabasics/basicstation · GitHub
But now I can work with TTN, but cannot with Chirpstack: it doesn’t send settings to Basic Station. Now I am looking for the reason.
Here is the log:
root@raspberrypi:~/basicstation/examples/corecell# ./start-station.sh -l ./lns-ttn
Using variant=debug, lns_config=‘./lns-ttn’
Starting Station …
2024-08-19 13:23:18.280 [SYS:INFO] Logging : stderr (maxsize=10000000, rotate=3)
2024-08-19 13:23:18.280 [SYS:INFO] Station Ver : 2.0.6(corecell/debug) 2024-08-19 06:26:59
2024-08-19 13:23:18.281 [SYS:INFO] Package Ver : 2.0.4
2024-08-19 13:23:18.281 [SYS:INFO] mbedTLS Ver : 2.28.0
2024-08-19 13:23:18.281 [SYS:INFO] proto EUI : b827:ebff:fef4:16d7 (station.conf)
2024-08-19 13:23:18.281 [SYS:INFO] prefix EUI : ::1 (builtin)
2024-08-19 13:23:18.281 [SYS:INFO] Station EUI : b827:ebff:fef4:16d7
2024-08-19 13:23:18.281 [SYS:INFO] Station home: ./lns-ttn/ (–home)
2024-08-19 13:23:18.281 [SYS:INFO] Station temp: /var/tmp/ (builtin)
2024-08-19 13:23:18.281 [SYS:WARN] Station in NO-CUPS mode
2024-08-19 13:23:18.482 [TCE:INFO] Starting TC engine
2024-08-19 13:23:18.482 [TCE:INFO] Connecting to INFOS: ws://192.168.0.79:3001
2024-08-19 13:23:18.483 [AIO:XDEB] [3] ws_connecting state=1
2024-08-19 13:23:18.484 [AIO:XDEB] [3] ws_connecting state=2
2024-08-19 13:23:18.484 [AIO:XDEB] [3] socket write bytes=167
2024-08-19 13:23:18.485 [AIO:XDEB] [3] ws_connecting state=3
2024-08-19 13:23:18.485 [AIO:XDEB] [3] socket read bytes=129
2024-08-19 13:23:18.485 [AIO:XDEB] [3|WS] > {“router”:“b827:ebff:fef4:16d7”}
2024-08-19 13:23:18.485 [AIO:XDEB] [3] socket write bytes=38
2024-08-19 13:23:18.486 [AIO:XDEB] [3] socket read bytes=119
2024-08-19 13:23:18.486 [AIO:XDEB] [3|WS] < {“router”:“b827:ebff:fef4:16d7”,“muxs”:“b827:ebff:fef4:16d7”,“uri”:“ws://192.168.0.79:3001/gateway/b827ebfffef416d7”}
2024-08-19 13:23:18.486 [TCE:INFO] Infos: b827:ebff:fef4:16d7 b827:ebff:fef4:16d7 ws://192.168.0.79:3001/gateway/b827ebfffef416d7
2024-08-19 13:23:18.486 [AIO:DEBU] [3] ws_close reason=1000
2024-08-19 13:23:18.486 [AIO:XDEB] [3] ws_closing_w state=5
2024-08-19 13:23:18.486 [AIO:DEBU] Echoing close - reason=1000
2024-08-19 13:23:18.486 [AIO:XDEB] [3] socket write bytes=8
2024-08-19 13:23:18.487 [AIO:DEBU] [3] Connection closed unexpectedly
2024-08-19 13:23:18.487 [AIO:DEBU] [3] WS connection shutdown…
2024-08-19 13:23:18.487 [TCE:VERB] Connecting to MUXS…
2024-08-19 13:23:18.488 [AIO:XDEB] [3] ws_connecting state=1
2024-08-19 13:23:18.488 [AIO:XDEB] [3] ws_connecting state=2
2024-08-19 13:23:18.488 [AIO:XDEB] [3] socket write bytes=180
2024-08-19 13:23:18.491 [AIO:XDEB] [3] ws_connecting state=3
2024-08-19 13:23:18.491 [AIO:XDEB] [3] socket read bytes=129
2024-08-19 13:23:18.491 [TCE:VERB] Connected to MUXS.
2024-08-19 13:23:18.491 [AIO:XDEB] [3|WS] > {“msgtype”:“version”,“station”:“2.0.6(corecell/debug)”,“firmware”:“2.0.4”,“package”:“2.0.4”,“model”:“corecell”,“protocol”:2,“features”:“rmtsh”}
2024-08-19 13:23:18.491 [AIO:XDEB] [3] socket write bytes=151
2024-08-19 13:24:18.493 [AIO:XDEB] [3] socket read bytes=2
2024-08-19 13:24:18.493 [AIO:XDEB] [3|WS] < PING ()
2024-08-19 13:24:18.493 [AIO:XDEB] [3|WS] > PONG
2024-08-19 13:24:18.493 [AIO:XDEB] [3] socket write bytes=6
2024-08-19 13:25:18.495 [AIO:XDEB] [3] socket read bytes=2
2024-08-19 13:25:18.495 [AIO:XDEB] [3|WS] < PING ()
2024-08-19 13:25:18.495 [AIO:XDEB] [3|WS] > PONG
2024-08-19 13:25:18.495 [AIO:XDEB] [3] socket write bytes=6
2024-08-19 13:26:18.496 [AIO:XDEB] [3] socket read bytes=2
2024-08-19 13:26:18.496 [AIO:XDEB] [3|WS] < PING ()
2024-08-19 13:26:18.496 [AIO:XDEB] [3|WS] > PONG
We found that the issue was an incorrect frequency in the ChirpStack Gateway Bridge. The ChirpStack Gateway Bridge was logging an error when generating the router_config response.
