Sorry for asking this non ChirpStack specific question in this forum, but i’m hoping someone can help.
I’ve got a IMST Lite Gateway with the ic880a concentrator that’s been connected to TTN with the Semtech UDP packet forwarder for the last couple of years.
Years ago I experimented with peer to peer Lora messages, so without LoraWAN. Recently I had the idea that my gateway should be able to receive these packets and that I could maybe process them locally with my own software.
As a first step I’ve configured a local server in local_conf.json of poly_pkt_fwd. Observing the UDP packets with tcpdump / Wireshark, it seems that the packets of my non LoRaWAN nodes are not being received / forwarded.
My test nodes send LoRa packets with the arduino-lora library:
I’ve changed the frequency to a valid TTN frequency:
if (!LoRa.begin(967700000)) {
Also tried explicitly setting specific preamble lengths (8 should be the default):
//LoRa.setPreambleLength(8);
//LoRa.setPreambleLength(12);
Is there something else I could try? My goal is to process non LoRaWAN packets with my own software and at the same time have my gateway connected to TTN (and ChirpStack soon
One thing I haven’t tried yet is changing the lorawan_public setting in global_conf.json:
"SX1301_conf": {
"lorawan_public": true,
