Recieving downlink messages from LNS on Grove Wio-e5
Hi, i am a student doing a first time project with LoRaWAN.
I have a LoRaWAN Network Server(LNS) running in docker, a gateway module (WM1302) with a Pi-hat on a rpi-3b and a Wio Grove-e5 Module connected to an Arduino Uno R3.
For a project i’m doing i would like to queue a message in the LNS and receive/read the message on the Arduino end node. I read online that this should be possible to do.
  • I have setup the network and connected the devices to it.
  • I can send an AT+MSGHEX=“payload” to the LNS and see it in the LoRaWAN frames tab.
  • The Arduino end node in configures to Class C and both the RXWIN1 and RXWIN2 are compliant with the EU region.
but when i try to queue a message to the Arduino i don’t read it there in the serial monitor.
for example:
  • I queue “48656C6C6F”, confirmed on FPORT 8
  • A new TXACK event appears in the event tab with downlinkId:2319993945
  • I check the logs on the gateway to see if it is received:
root@chirpstack:~# logread | grep "2319993945"
Tue Feb  4 14:01:38 2025 user.info chirpstack-mqtt-forwarder[3137]: Received downlink command, downlink_id: 2319993945, topic: eu868/gateway/0016c001f1050e73/command/down
Tue Feb  4 14:01:38 2025 user.info chirpstack-mqtt-forwarder[3137]: Sending downlink frame, downlink_id: 2319993945
Tue Feb  4 14:01:38 2025 user.info chirpstack-concentratord-sx1302[2091]: Enqueueing immediate packet, downlink_id: 2319993945, current_counter_us: 3996888924
Tue Feb  4 14:01:38 2025 user.info chirpstack-mqtt-forwarder[3137]: Received ack, items: ["OK"], downlink_id: 2319993945
Tue Feb  4 14:01:38 2025 user.info chirpstack-mqtt-forwarder[3137]: Sending ack event, downlink_id: 2319993945, topic: eu868/gateway/0016c001f1050e73/event/ack
Tue Feb  4 14:01:39 2025 user.info chirpstack-concentratord-sx1302[2091]: Scheduled packet for TX, downlink_id: 2319993945, count_us: 3997888924, freq: 869525000, bw: 125000, mod: LoRa, dr: SF12
i am using this sketch on the Arduino
#include <SoftwareSerial.h>
// Setup SoftwareSerial for the Wio-E5 module.
SoftwareSerial wioSerial(11, 10); // RX, TX
// Timeouts and delays (adjust as needed)
const unsigned long joinTimeout    = 15000;  // Maximum time (in ms) to wait for join messages
const unsigned long postDoneDelay  = 1000;   // Delay after "Done" to ensure join confirmation
const unsigned long retryDelay     = 2000;   // Delay between join attempts
// Forward declarations
String sendATCommandAndWait(String command, unsigned long timeoutMS = 300);
void joinNetwork();
void flushSerial();
void setup() {
  Serial.begin(9600);       // Monitor Serial
  wioSerial.begin(9600);     // Wio‑E5 baud rate
  delay(1000);
  Serial.println("Initializing Wio‑E5...");
  // Set log to quiet (optional) and switch to Class C mode.
  flushSerial();
  sendATCommandAndWait("AT+LOG=LOG", 300);
  delay(100);
  sendATCommandAndWait("AT+CLASS=C, SAVE", 500);
  delay(100);
  // Join the network (for OTAA, if needed).
  joinNetwork();
  delay(1000);
  sendATCommandAndWait("AT+CMSGHEX=\"48656C6C6F\"", 1000);
    while (wioSerial.available()) {
    char c = wioSerial.read();
    Serial.write(c);  // Directly output the character to the Serial Monitor.
  //delay(2500);
  //Serial.println("Configuration complete. Now listening for downlink messages...");
void loop() {
  // Instead of reading by line, read character-by-character:
  // A short delay can help avoid overwhelming the loop.
  //delay(5);
I’m not sure what i am doing wrong. Feel free to reply if i left out any important information. Hopefully my peers can point me in the right direction. Thanks a lot in advance.
As addition to my troubleshooting. When i re-opened the serial monitor, the AT+CMSG command got executed, which cause a message to be send to the LNS. Curiously, after sending the message i was able to receive a downlink message from the LNS. See the log below:
13:54:23.911 -> Sending: AT+LOG=DEBUG
13:54:24.223 -> Raw response: +LOG: DEBUG
13:54:24.223 ->
13:54:24.300 -> Sending: AT+CLASS=?
13:54:24.804 -> Raw response: +CLASS: C
13:54:24.840 ->
13:54:24.922 -> Attempting to join network...
13:54:24.955 -> Received: +JOIN: Joined already
13:54:25.938 -> Joined network successfully.
13:54:26.967 -> Sending: AT+CMSGHEX="48656C6C6F"
13:54:27.966 -> Raw response: +LOG:  WARN 16154586 LW      tx 8, 48656C6C6F(5)
13:54:28.031 -> +CMSGHEX: Start
13:54:28.064 -> +CMSGHEX: Wait ACK
13:54:28.097 -> +LOG: DEBUG 16154587 LW      ch 04
13:54:28.129 -> +LOG: DEBUG 16154587 LORA    TX, 867300000, SF7, 125KHz, 8, 2
13:54:28.195 -> +LOG: DEBUG 16154587 LORA    TX, 801D2D8201A0070008D142224036C4016238
13:54:28.261 -> +LOG: DEBUG 16154643 LORA    RX, 869525000, SF12, 125KHz, 0
13:54:28.326 ->
13:54:28.326 -> +LOG: DEBUG 16155634 LORA    RX, 867300000, SF7, 125KHz, 24
13:54:28.392 -> +LHEX: FPENDING
13:54:28.424 -> +CMSGHEX: ACK Received
13:54:28.424 -> +CMSGHEX: PORT: 8; RX: "74657374"
13:54:28.457 -> +CMSGHEX: RXWIN1, RSSI -22, SNR 9.0
13:54:28.531 -> +CMSGHEX: Done
13:54:30.419 -> +LOG: DEBUG 16157994 LORA    RX, A01D2D8201A0080008E43E1729ED9C5577, -11, 5
13:54:30.490 -> +LOG: DEBUG 16157999 LORA    RX, 869525000, SF12, 125KHz, 0
13:56:18.303 -> +LOG: DEBUG 16265908 LORA    RX, 60F7C12A1420B20000976C0291C7, -101, -13
13:56:18.413 -> +LOG: DEBUG 16265912 LORA    RX, 869525000, SF12, 125KHz, 0
This behaviour i would expect when i set my LoRa module to class A, which would open a windows for downlinks to be received. But as the logs show my module is set to class C after asking the state of it. But it still behaves like it would in class A. I am not able to receive messages any more after this. Only when i recreate this specific scenario. hope this additional info is useful.
I made a short test with my Wio Grove-e5.
  • AT+CLASS=C
  • AT+JOIN
  • AT+MSGHEX=“12345678”
After sending the message, I added messages to the queue and received them always at once on the Wio Grove-e5
+LOG: DEBUG  1463588 LORA    RX, 601D9A70C4800500014CE4E4293FD4, -21, 5
+LOG: DEBUG  1463592 LORA    RX, 869525000, SF12, 125KHz, 0
+MSG: PORT: 1; RX: "1234"
+MSG: RXWIN0, RSSI -21, SNR 5.0
+MSG: Done
So the behavior of the Wio Grove-e5 itself seems to be ok for class C.
Thanks for our reply. I think we are understand each other incorrectly. I have two of the same modules but one of the modules behaves differently then the other one when i follow the steps i described in my original post. So it seems unlikely to me that this is normal behavior. I did additional tests in test mode and send packets with ‘AT+TEST=TXLRPKT’ and ‘AT+TEST=RXLRPKT’ in test mode. One of the modules refuses to send a message to the other and reverts back to OWOTAA after attempting to send the message. Despite this it has no problem receiving messages in test mode while listening, it only reverts back to LWOTAA when sending a message. I can only conclude that this behavior must be an hardware error. currently i can work around this issue and I have ordered a new module.
thanks for you help, kind regards.
