Hi there,
We currently have the stack in these old version :
- Loraappserver : 0.21.0
- Gatewaybridge : 2.4.0
- Loraserver: 0.26.3
And we want to upgrade to the latest version. We have already set up a new server with new stack and it is working with our sensors so our new config files are OK. We have also the outputed data form sensors on MQTT.
During the migration, I steped the upgrade with these versions for network server :
- 1.0.0
- 2.0.0
- 2.8.2
- 3.0.0
- latest
We got no error for the postgres db, so I did the same process for app server part :
- 1.0
- 2.0.0
- 2.6.1
- 3.0.0
- 3.1.0
- 3.3.0
- latest
Right here, no problem with postgres part. Finally for the gateway bridge, I directly use the latest version available.
But I think the redis data format was not properly upgraded to the new protobuf format introduced in network server v2.0.0 (according to changelog https://www.chirpstack.io/network-server/overview/changelog/)
Here is some stuff making me thinking this :
- this error “wrong type (lorawan.AES128Key) for received device session nwkskey (code 2)” - see attached screenshot
- these logs in the app server when displaying the above page :
time=“2019-11-07T08:42:13Z” level=error msg=“finished client unary call” ctx_id=25ed3198-d7f1-44ad-b495-12174b7fb09d error=“rpc error: code = Unknown desc = gob: wrong type (lorawan.AES128Key) for received field DeviceSession.NwkSKey” grpc.code=Unknown grpc.ctx_id=b1e2b66b-f150-4ef3-9397-81b2d1297a93 grpc.duration=1.998309ms grpc.method=GetDeviceActivation grpc.service=ns.NetworkServerService span.kind=client system=grpc
time=“2019-11-07T08:42:13Z” level=error msg=“finished unary call with code Unknown” ctx_id=25ed3198-d7f1-44ad-b495-12174b7fb09d error=“rpc error: code = Unknown desc = gob: wrong type (lorawan.AES128Key) for received field DeviceSession.NwkSKey” grpc.code=Unknown grpc.method=GetActivation grpc.service=api.DeviceService grpc.start_time=“2019-11-07T08:42:12Z” grpc.time_ms=194.45 peer.address=“127.0.0.1:55438” span.kind=server system=grpc - I went into the redis and displayed 2 keys : one for a previous device (using ABP) added before the upgrade (devEUI 000000002100b46a) and another one (devEUI 0018b200000211db) which had the old data format (not working), so I made a new JR/JA and the device was working after, but the keys was regenerated during OTAA and keys format in redis seems to have been upgraded/regenerated
Here is the data :
127.0.0.1:6379> get lora:ns:device:000000002100b46a
"\xfe\x02\xa5\xff\x9d\x03\x01\x01\rDeviceSession\x01\xff\x9e\x00\x01$\x01\x0fDeviceProfileID\x01\x0c\x00\x01\x10ServiceProfileID\x01\x0c\x00\x01\x10RoutingProfileID\x01\x0c\x00\x01\aDevAddr\x01\xff\xa0\x00\x01\x06DevEUI\x01\xff\x86\x00\x01\aJoinEUI\x01\xff\x86\x00\x01\aNwkSKey\x01\xff\xa2\x00\x01\x06FCntUp\x01\x06\x00\x01\bFCntDown\x01\x06\x00\x01\x12SkipFCntValidation\x01\x02\x00\x01\bRXWindow\x01\x04\x00\x01\aRXDelay\x01\x06\x00\x01\x0bRX1DROffset\x01\x06\x00\x01\x05RX2DR\x01\x06\x00\x01\x0cRX2Frequency\x01\x04\x00\x01\x0cTXPowerIndex\x01\x04\x00\x01\x02DR\x01\x04\x00\x01\x03ADR\x01\x02\x00\x01\x18MinSupportedTXPowerIndex\x01\x04\x00\x01\x18MaxSupportedTXPowerIndex\x01\x04\x00\x01\x0eMaxSupportedDR\x01\x04\x00\x01\aNbTrans\x01\x06\x00\x01\x0fEnabledChannels\x01\xff\xa4\x00\x01\x15EnabledUplinkChannels\x01\xff\xa4\x00\x01\x13ExtraUplinkChannels\x01\xff\xa8\x00\x01\x12ChannelFrequencies\x01\xff\xa4\x00\x01\rUplinkHistory\x01\xff\xac\x00\x01\rLastRXInfoSet\x01\xff\xae\x00\x01\x16LastDevStatusRequested\x01\xff\x88\x00\x01\x14LastDevStatusBattery\x01\x06\x00\x01\x13LastDevStatusMargin\x01\x04\x00\x01\x0eLastDownlinkTX\x01\xff\x88\x00\x01\x0cBeaconLocked\x01\x02\x00\x01\nPingSlotNb\x01\x04\x00\x01\nPingSlotDR\x01\x04\x00\x01\x11PingSlotFrequency\x01\x04\x00\x00\x00\x13\xff\x9f\x06\x01\x01\aDevAddr\x01\xff\xa0\x00\x00\x00\x11\xff\x85\x06\x01\x01\x05EUI64\x01\xff\x86\x00\x00\x00\x19\xff\xa1\x01\x01\x01\tAES128Key\x01\xff\xa2\x00\x01\x06\x01 \x00\x00\x13\xff\xa3\x02\x01\x01\x05[]int\x01\xff\xa4\x00\x01\x04\x00\x00%\xff\xa7\x04\x01\x01\x14map[int]band.Channel\x01\xff\xa8\x00\x01\x04\x01\xff\xa6\x00\x00.\xff\xa5\x03\x01\x02\xff\xa6\x00\x01\x03\x01\tFrequency\x01\x04\x00\x01\x05MinDR\x01\x04\x00\x01\x05MaxDR\x01\x04\x00\x00\x00&\xff\xab\x02\x01\x01\x17[]storage.UplinkHistory\x01\xff\xac\x00\x01\xff\xaa\x00\x00Q\xff\xa9\x03\x01\x01\rUplinkHistory\x01\xff\xaa\x00\x01\x04\x01\x04FCnt\x01\x06\x00\x01\x06MaxSNR\x01\b\x00\x01\x0cTXPowerIndex\x01\x04\x00\x01\x0cGatewayCount\x01\x04\x00\x00\x00\x18\xff\xad\x02\x01\x01\tRXInfoSet\x01\xff\xae\x00\x01\xff\x9a\x00\x00v\xff\x99\x03\x01\x01\x06RXInfo\x01\xff\x9a\x00\x01\b\x01\x03MAC\x01\xff\x86\x00\x01\x04Time\x01\xff\x88\x00\x01\x11TimeSinceGPSEpoch\x01\x04\x00\x01\tTimestamp\x01\x06\x00\x01\x04RSSI\x01\x04\x00\x01\aLoRaSNR\x01\b\x00\x01\x05Board\x01\x04\x00\x01\aAntenna\x01\x04\x00\x00\x00\n\xff\x87\x05\x01\x02\xff\x8e\x00\x00\x00\xfe\x02\x11\xff\x9e\x01$836e8ada-679e-4fc4-a816-31a385afa48f\x01$a1f47f30-dee1-466a-a919-3174014f615d\x01$6d5db27e-4ce2-4b2b-b5d7-91f069397978\x01\x04j\xb4\x00!\x01\bj\xb4\x00!\x00\x00\x00\x00\x02\x10\x19\xff\x84+\xff\xd9GC$k6|.\xff\x90\xff\x94*\x1fr\x01\xfe\x16\xf3\x01\xfe\x01v\x01\x01\x02\x01\x03\xfcg\xa7\xcc\x10\x02\n\x05\x01\x02\x03\x00\x02\x04\x01\x00\x02\x14\x01\xfe\x16\xdf\x01\xfe\x16@\x02\x02\x00\x01\xfe\x16\xe0\x01\xf8\x9a\x99\x99\x99\x99\x99%@\x02\x02\x00\x01\xfe\x16\xe1\x01\xfe&@\x02\x02\x00\x01\xfe\x16\xe2\x01\xfe#@\x02\x02\x00\x01\xfe\x16\xe3\x01\xf8ffffff\"@\x02\x02\x00\x01\xfe\x16\xe4\x01\xf8ffffff$@\x02\x02\x00\x01\xfe\x16\xe5\x01\xfe%@\x02\x02\x00\x01\xfe\x16\xe6\x01\xf8\x9a\x99\x99\x99\x99\x99!@\x02\x02\x00\x01\xfe\x16\xe7\x01\xf8ffffff$@\x02\x02\x00\x01\xfe\x16\xe8\x01\xf8ffffff\"@\x02\x02\x00\x01\xfe\x16\xe9\x01\xfe$@\x02\x02\x00\x01\xfe\x16\xea\x01\xfe\x1e@\x02\x02\x00\x01\xfe\x16\xeb\x01\xfe%@\x02\x02\x00\x01\xfe\x16\xec\x01\xf8\x9a\x99\x99\x99\x99\x99%@\x02\x02\x00\x01\xfe\x16\xed\x01\xf8ffffff&@\x02\x02\x00\x01\xfe\x16\xee\x01\xfe\"@\x02\x02\x00\x01\xfe\x16\xef\x01\xfe%@\x02\x02\x00\x01\xfe\x16\xf0\x01\xfe\"@\x02\x02\x00\x01\xfe\x16\xf1\x01\xfe\"@\x02\x02\x00\x01\xfe\x16\xf2\x01\xf8\x9a\x99\x99\x99\x99\x99#@\x02\x02\x00\x01\x01\x01\b\xf0\x00\x00 \x00\x00\x00\x00\x01\x0f\x01\x00\x00\x00\x0e\xd5T\x82~5~\x13\x98\xff\xff\x02\xfc\xb7\x84\x05\xf3\x01\xff\xcb\x01\xf8\x9a\x99\x99\x99\x99\x99#@\x00\x03\xff\xfe\x01\x0f\x01\x00\x00\x00\x0e\xd5T\x82\x7f\x17\xca\xea\xad\x00\x00\x00"
127.0.0.1:6379> get lora:ns:device:0018B200000211DB
(nil)
127.0.0.1:6379> get lora:ns:device:0018b200000211db
"\n$c6befdf9-c5af-4ac9-93f7-d4721c3c9f03\x12$3cf1abef-8952-4d1e-95f9-81cca85d9c08\x1a$6d5db27e-4ce2-4b2b-b5d7-91f069397978\"\x04\x06\\=\x89*\b\x00\x18\xb2\x00\x00\x02\x11\xdb2\b\xcb)\x87\xe4:\x06\xbe\xf5:\x10\xde\xd3\x1f\xc7\x12\x04\xc6\xa6\xae\xdb\x1e\\C\xe7\xcdCB\x10\xde\xd3\x1f\xc7\x12\x04\xc6\xa6\xae\xdb\x1e\\C\xe7\xcdCJ\x10\xde\xd3\x1f\xc7\x12\x04\xc6\xa6\xae\xdb\x1e\\C\xe7\xcdCP\x06X\x05p\x01\x88\x01\x88\xcc\xcf\x9e\x03\x90\x01\x01\xa0\x01\x01\xa8\x01\x05\xb8\x01\x01\xc2\x01\x03\x00\x01\x02\xda\x01\t\b\x01\x15\x00\x00\xe0@ \x01\xda\x01\x0b\b\x02\x15\x00\x00\x18A\x18\x01 \x01\xda\x01\x0b\b\x03\x15\x00\x00\x00A\x18\x01 \x01\xda\x01\x0b\b\x04\x15\x00\x00(A\x18\x01 \x01\xda\x01\x0b\b\x05\x15\x00\x00 A\x18\x01 \x01\xe8\x01\x80\x80\xe8\xe8\xb3\xfd\x80\xd9\xa1\x01\x80\x02\x8d\xe4\xf4\x85\xc2\xe9\xb4\xea\x15\xaa\x02\x051.0.1\xb0\x02\x01"
Am I right thinking this error is coming from here ?
How we can have the redis data upgraded to new protobuf format ? Many of our nearly 100000 devices recorded in network server are using abp, so we can’t use OTAA rejoin to regenerate keys.
Many thanks
