I always get the same error message through various places on the Web-GUI of the Application Server:
I searched through the forum and the error message seems to be related to Redis.
I’m on Debian 11.6 and Redis 6.0.16. My configuration for redis in /etc/chirpstack-application-server/chirpstack-application-server.toml looks like this:
# Redis settings
# Please note that Redis 2.6.0+ is required.
[redis]
servers=[
"localhost:6379",
# Password.
# Set the password when connecting to Redis requires password authentication.
password=""
# Database index.
# By default, this can be a number between 0-15.
database=0
# Redis Cluster.
# instance.
cluster=false
# Master name.
# Set the master name when the provided URLs are pointing to a Redis Sentinel
# instance.
master_name=""
# Connection pool size.
# Default (when set to 0) is 10 connections per every CPU.
pool_size=0
# TLS enabled.
# Note: this will enable TLS, but it will not validate the certificate
# used by the server.
tls_enabled=false
# Key prefix.
# A key prefix can be used to avoid key collisions when multiple regions
# are using the same Redis database and it is not possible to separate
# keys by database index (e.g. when using Redis Cluster, which does not
# support multiple databases).
key_prefix=""
I configured it the same in the file /etc/chirpstack-network-server/chirpstack-network-server.toml.
Any suggestions how to fix this? Thanks
