Hi @brocaar! How r u doing man!
Postgresql databases just increase in system memory even we drop registers from frame_logs table, for example.
However, it might be exists some commands that we could do for reduce postgresql size for the internal reral use size and fit it.
Please, do you know the security command we can type for this job?
Thanks man!
Best Regards!
Hi @brocaar!
Whats up!
Please, do you have any ideas to solve this increasing not decreasing postgresql database?
You are referring to the frame_logs
, please note that this table is not in use anymore since a long time. Are you running an older version?
Also about what increase are we talking about?
Maybe this command is useful for debugging? https://www.a2hosting.com/kb/developer-corner/postgresql/determining-the-size-of-postgresql-databases-and-tables
