ChirpStack Application Server v3.11.0-test.1
Features
OpenID Connect authentication
This feature makes it possible to use an OpenID Connect authentication backend together with ChirpStack Application Server, for example Auth0.com. Users are automatically matched based on email address on the first login. If there is a succesful match, an external OpenID Connect user identifier is associated with the user, so that even in case of an email address update, it can still be matched (and updated in the ChirpStack Application Server database).
The implementation of this feature required a couple of changes:
Usernames
Usernames no longer exist in ChirpStack Application Server and have been renamed to email. Existing users can still login with their username, but on user update, the username must be set to an email address.
Previously there was an unused email field. As there was no guarantee that this field was unique this field has been deprecated. It is still present in the database as email_old
so that the new email
field (containing the old username
as value) can be updated by hand if needed.
Create users
Creating new users as an organization admin has been removed. However, the OpenID Connect integration provides a registration_enabled
option, which automatically creates new users when it does not exist.
Together with the registration_callback_url
, it can be used to automatically onboard new users. When this option is set, ChirpStack Application Server will make a HTTP request to configured URL when a new user is created. This makes it possible to implement an onboarding service which (using the API) could:
- Create an organization for the given user ID
- Setup one or multiple service-profiles
Assigning users to organization
Previously there was an auto-complete field to assign an user to an organization. As the username has been replaced by email and to not leak email addresses, the autocomplete function has been removed and the exact email must be given when associating a given user with an organization.
LoRa Cloud geolocation
This migrates the geolocation integration from ChirpStack Network Server to ChirpStack Application Server and allows a per-application integration configuration. The current integration provides support for TDOA and RSSI based geolocation. This will be extended by future releases to also support the LR1110 capabilities.
Disable device
This feature makes it possible to (temporarily) disable a device.
Improvements
- Make it possible to use activate API endpoint for OTAA devices (to import an existing activation).
- Gateway Profile / channel-plan re-configuration documentation in web-interface.
- Internal cleanup auto-complete select in web-interface.
- Expose (un)confirmed + DevAddr in integration payloads. (#453)
- Highlight rlow when hovering over table rows in web-interface. (#474)
- Include Network Server name column in Device- and Service Profile list. (#475)
- Include RSSI and SNR in ThingsBoard integration. (#478)
- Align Gateway detail overview styling. (#480)
Bugfixes
- Fix delete icon in gateway-profile UI (was showing + icon instead of delete).
Testing
Debian
Use the testing
channel instead of stable
sudo echo "deb https://artifacts.chirpstack.io/packages/3.x/deb testing main" | sudo tee /etc/apt/sources.list.d/chirpstack.list
Docker
Use the chirpstack/chirpstack-application-server:3.11.0-test.1
image and tag (will be available shortly).
