ChirpStack Application Server v3.6.0-test.2
Features
Protobuf based integrations
This feature adds a marshaler
configuration option to the integration configuration. The default is backwards compatible with the current JSON format. New options are protobuf
(Protobuf binary) and json
(Protobuf based JSON).
Improvements
gRPC / Protobuf cleanup
All definitions are now imported from github.com/brocaar/chirpstack-api/go
. When using the gRPC API, you must update your imports.
Azure Service-Bus integration
Implement re-connect in case of an Azure Service-Bus error. This to work partly around azure-service-bus-go/issues/149.
Support multiple HTTP endpoints
Implement support for configuring multiple endpoints in the HTTP integration.
Testing
Debian
Use the testing
channel instead of stable
sudo echo "deb https://artifacts.chirpstack.io/packages/3.x/deb testing main" | sudo tee /etc/apt/sources.list.d/chirpstack.list
Docker
Use the chirpstack/chirpstack-application-server:3.6.0-test.2
image and tag (available shortly).
