This new integration publishes device events to an AMQP / RabbitMQ message broker.
Device variables in JS codec
This makes it possible to store (for example) calibration values as device variables and use this variable in the JavaScript codec.
Improvements
API auth query cleanup
This cleanup optimizes the API authorization functions by using a SQL query specific to each function, instead of a shared SQL query joining all tables.
Testing
Debian
Use the testing channel instead of stable:
sudo echo "deb https://artifacts.chirpstack.io/packages/3.x/deb testing main" | sudo tee /etc/apt/sources.list.d/chirpstack.list
Docker
Use the chirpstack/chirpstack-application-server:3.7.0-test.1 image and tag (available shortly).
Improvements
Connection settings
Implement max. reconnect interval setting for MQTT integration.
Fix Redis max. idle configuration and add max. active connections configuration.
Implement max open and idle connections for PostgreSQL integration.
Bugfixes
Check for null values in JSONTree web-interface component. (#398)
