v4.2.0
Features
Refactor model configuration
This release adds a region configuration option and removes the region suffix from the gateway / shield model. This changes the configuration from:
model="rak_rak2247_eu868"
to:
model="rak_rak2247"
region="EU868"
For backwards compatibility, the old model configuration remains valid in this version, but will be removed in v4.3.0.
Other features
- Add
CN470support forsemtech_sx1302c490gw1shield. - Add
AU915support forsandbox_lorago_portshield. - Add fine-timestamp for SX1302/SX1302. (#66)
Improvements
Build improvements
The provided pre-compiled binaries are fully static and based on musl libc. This removes the need to compile against a very old verion of glibc to stay compatible with old gateway firmwares.
Other improvements
- Update internal dependencies.
- Implement time fallback option in case no GPS time-source is available. (#49)
Bugfixes
- Fix Class-B beacon channel-hopping.
- Fix typo in
2g4logs (it would log under thechirpstack-concentratord-sx1301process name).
