ChirpStack Gateway Bridge v3.11.0-test.1
Features
Connection state messages
This publishes a conn state message, indicating if a gateway is online or offline. State messages are published as retained so that a MQTT client will immediately receive the latest state of the gateway(s) after subscribing to the conn state MQTT topic. The default MQTT topic for state messages is gateway/ID/state/STATE where ID is the ID of the gateway and STATE is the state (in this case conn). This topic is configurable in the Configuration.
Improvements
- When
terminate_on_connect_erroris enabled, terminate on connection lost. (#184) - Do not run as root (Docker). (#185)
- Add ns precision to log output timestamp.
Bugfixes
- Add websocket connection mutex to avoid concurrent writes. (#191)
Testing
Debian
Use the testing channel instead of stable:
sudo echo "deb https://artifacts.chirpstack.io/packages/3.x/deb testing main" | sudo tee /etc/apt/sources.list.d/chirpstack.list
Docker
Use the chirpstack/chirpstack-gateway-bridge:3.11.0-test.1 image and tag.
