v3.14.0
Features
- Add support for periodic time-sync requests (Basics Station).
Improvements
- Make it possible to use 32bit downlink tokens instead of 16bit only (will be used by ChirpStack v4).
v3.14.1
Improvements
- Update dependencies.
- Update to Go 1.18.
v3.14.2
Bugfixes
- Basics Station: Prefer
gpstime over rxtime in case both are available.
brocaar
4
v3.14.3
Bugfixes
- Fix incorrect handling of MQTT token timeout, causing re-connect to not work in some cases. (#210)
v3.14.4
Improvements
- Update build to latest Go toolchain.
v3.14.5
Improvements
- Expose ack-rate (Semtech UDP protocol) through Prometheus metrics.
Bugfixes
- Update Multitech Conduit packaging to work Monit for process monitoring (included in latest mPower).
brocaar
7
v3.14.6
Improvements
- Update Go compiler to v1.19.3.
- Update Alpine base container to v3.17.0.
- Update prometheus/client_golang to v1.14.0.
v3.14.7
Bugfixes
- Prevent duplicate MQTT connections. (#229)
