ChirpStack Gateway Bridge v3.7.0-test.2
Features
Concentratord backend
The Concentratord backend is compatible with the ChirpStack Concentratord daemon. Please note that this backend is experimental.
Syslog output
When log_to_syslog
is enabled in the configuration file, the log output will be written to syslog.
Improvements
- Change MQTT max. reconnect interval default value to 1 minute.
- Refactor MQTT subscribe / unsubscribe logic.
Bugfixes
- Use DevEUI object length instead of JoinEUI. (#154)
- Remove default values for BasicStation filters. (#157)
- Fix BasicStation websocket ping loop. (#156)
Testing
Debian
Use the testing
channel instead of stable
sudo echo "deb https://artifacts.chirpstack.io/packages/3.x/deb testing main" | sudo tee /etc/apt/sources.list.d/chirpstack.list
Docker
Use the chirpstack/chirpstack-gateway-bridge:3.7.0-test.2
image and tag.
