v3.3.0-test.1
This is a rewrite of the ChirpStack Gateway OS, you must re-flash your SD Card to update! Currently this version only targets the Raspberry Pi 3.
Features
- Yocto has been updated to version 3.0.
- Software updates are now handled by SWUpdate.
- The Semtech UDP Packet Forwarder has been replaced by ChirpStack Concentratord.
Updates
Fixes
- Redis database does not start on boot after power failure that corrupts append only file. (#32)
ChirpStack Gateway OS v3.3.0-test.4
When updating from a previous v3.3.0 version, it is recommended to re-run the gateway-config utility to update the concentrator configuration.
Updates
Hi @brocaar,
I tried Chirpstack Gateway OS for Raspberry Pi 3. I tried both (base and full) on both shields RisingHF RHF0M301 and RAK 831, with same issue. It seems ConcentratorD is having some problem to run.
tail -f /var/log/messages shows lots of lines like:
Mar 26 01:06:47 raspberrypi3 user.err chirpstack-gateway-bridge[459]: time="2020-03-26T01:06:47Z" level=error msg="backend/concentratord: event socket dial error" error="dial event api url error: zmq4: could not dial to \"ipc:///tmp/concentratord_event\": dial unix /tmp/co
Mar 26 01:06:50 raspberrypi3 user.err chirpstack-gateway-bridge[459]: time="2020-03-26T01:06:50Z" level=error msg="backend/concentratord: event socket dial error" error="dial event api url error: zmq4: could not dial to \"ipc:///tmp/concentratord_event\": dial unix /tmp/co
Mar 26 01:06:54 raspberrypi3 user.err chirpstack-gateway-bridge[459]: time="2020-03-26T01:06:54Z" level=error msg="backend/concentratord: event socket dial error" error="dial event api url error: zmq4: could not dial to \"ipc:///tmp/concentratord_event\": dial unix /tmp/co
Mar 26 01:06:57 raspberrypi3 user.err chirpstack-gateway-bridge[459]: time="2020-03-26T01:06:57Z" level=error msg="backend/concentratord: event socket dial error" error="dial event api url error: zmq4: could not dial to \"ipc:///tmp/concentratord_event\": dial unix /tmp/co
Mar 26 01:07:01 raspberrypi3 user.err chirpstack-gateway-bridge[459]: time="2020-03-26T01:07:01Z" level=error msg="backend/concentratord: event socket dial error" error="dial event api url error: zmq4: could not dial to \"ipc:///tmp/concentratord_event\": dial unix /tmp/co
Mar 26 01:07:04 raspberrypi3 user.err monit[445]: 'chirpstack-concentratord' failed to start (exit status 1) -- '/etc/init.d/chirpstack-concentratord start': Configuration file does not exist
Mar 26 01:07:04 raspberrypi3 user.err chirpstack-gateway-bridge[459]: time="2020-03-26T01:07:04Z" level=error msg="backend/concentratord: event socket dial error" error="dial event api url error: zmq4: could not dial to \"ipc:///tmp/concentratord_event\": dial unix /tmp/co
Mar 26 01:07:08 raspberrypi3 user.err chirpstack-gateway-bridge[459]: time="2020-03-26T01:07:08Z" level=error msg="backend/concentratord: event socket dial error" error="dial event api url error: zmq4: could not dial to \"ipc:///tmp/concentratord_event\": dial unix /tmp/co
Mar 26 01:07:11 raspberrypi3 user.err chirpstack-gateway-bridge[459]: time="2020-03-26T01:07:11Z" level=error msg="backend/concentratord: event socket dial error" error="dial event api url error: zmq4: could not dial to \"ipc:///tmp/concentratord_event\": dial unix /tmp/co
Mar 26 01:07:14 raspberrypi3 user.err monit[445]: 'chirpstack-concentratord' process is not running
Mar 26 01:07:14 raspberrypi3 user.info monit[445]: 'chirpstack-concentratord' trying to restart
Mar 26 01:07:14 raspberrypi3 user.info monit[445]: 'chirpstack-concentratord' start: '/etc/init.d/chirpstack-concentratord start'
Mar 26 01:07:15 raspberrypi3 user.err chirpstack-gateway-bridge[459]: time="2020-03-26T01:07:15Z" level=error msg="backend/concentratord: event socket dial error" error="dial event api url error: zmq4: could not dial to \"ipc:///tmp/concentratord_event\": dial unix /tmp/co
M
I did in every case:
Afer that, /etc/chirpstack-concentratord/sx1301/global.toml is filled with default values. I change them (model=“generic_us915”, and gateway_id= random number)
/etc/chirpstack-concentratord/sx1301/band.toml is empty
/etc/chirpstack-concentratord/sx1301/channels.toml is empty. I populated with
[gateway.concentrator]
# US915 sub Band 2
multi_sf_channels=[
903900000,
904100000,
904300000,
904500000,
904700000,
904900000,
905100000,
905300000,
[gateway.concentrator.lora_std]
frequency=904600000
bandwidth=500000
spreading_factor=8
I have to admit that this is my first time with chirpstack-concentratord. I would really appreciate any clue regarding this.
With best regards
Sebastian
ChirpStack Gateway OS v3.3.0-test.5
Updates
Features
Wifi Access Point mode
On initial installation on a Raspberry Pi 3, the Raspberry Pi will start Wifi in Access Point mode, so that it is possible to connect directly to the Raspberry Pi over WIFI for configuration of the concentrator shield and to re-configure the WIFI.
Improvements
- RAK2245 configuration has been improved (using defined Concentratord model name).
- RAK832 configuration has been improved.
- RAK2245 / RAK831 AS923 channel-plan has been added. (#43)
Bugfixes
- Fix passing incorrect model flags in
gateway-config for some gateways.
The above release might fix your issue. Could you re-try with that version?
Hi @brocaar,
Thank you for your reply.
Yes! The new version works with RAK831. I haven’t tried with RisingHF, thought.
WiFi in access point is very clever. Specially when you don’t have access to DHCP Server.
Thank you again!
Great and thanks for testing! The WiFi in access point mode is needed to provide support for the Raspberry Pi Zero Wireless (coming soon), which does not have an ethernet port. Glad you like it!
Thank you for your support!
I forgot to mention that WiFi in access point is good for RAK831 as well. The HAT adapter takes over serial pins, making impossible to access serial console.
This marks the first non-testing release of the ChirpStack Gateway OS!
Updates
Hello everyone, I have installed the ChirpStack Gateway OS v3.3.0-test.2 configuration on my imst lite gateway.
I would like to connect to my remote hirpStack Network Server.
in practice the gateway should only do packet forward to the remote server and remote server applicatio.
I usually configure global_conf and that’s it.
in this case I am afraid I have not understood how it works. it seems that the gateway also acts as a lora bridge?
Could you help me
thank you so much
