[release] ChirpStack Gateway OS v4.2 test releases
Thanks for confirming @Xornix and @corty. I usually limit the changelog items between the stable versions. E.g. if an issue was introduced by a test-version, which is fixed by the next test-version then I do not include this.
Just to summarize what I did between test.1 and test.2:
Is there any chance of a config variable for the sx1302_reset_pin on sx1302 for concentratord?
I’m using an old RAK helium miner as a chirpstack gateway - its pretty much the same as the rak_2287_eu868 but needs sx1302_reset_pin=25 setting in concentratord.conf to be detected.
Thanks a lot @brocaar for solving it so quickly and then taking the time to explain ! Amazing level of support here !
test-version 3, make a squashfs-sysupgrade, System is stable, client receive stats
Please create a request (or even better, a pull-request) for this in: GitHub - chirpstack/chirpstack-concentratord: Concentrator HAL daemon for LoRa gateways. :slight_smile:
Would this be better off as an issue in the gatewayos v4.2 github repo?
concentratord seems to support and use the sx1302_reset_pin, its the file management by luci / openwrt / GatewayOS overwriting that which seems to be the problem :slight_smile:
Ah yes, in that case please create an issue (or PR) in the GW OS repo to make this configurable through LuCI / UCI config system.
Were you ever able to get this working?
I am banging my head against the wall with an old 2287 Miner card!
Thanks,
Phil
