In the web-interface I have selected SX1301 + Sandbox LoRaGO PORT shield with EU868 and it works as expected.
As an additional test from the CLI (over SSH):
/etc/init.d/chirpstack-concentratord stop
Then:
cd /var/etc/chirpstack-concentratord
concentratord.toml
[concentratord]
# Log level.
# Valid options are:
# * TRACE
# * DEBUG
# * INFO
# * WARN
# * ERROR
# * OFF
log_level="INFO"
# Log to syslog.
# When set to true, log messages are being written to syslog instead of stdout.
log_to_syslog=false
# Statistics interval.
stats_interval="30s"
# Configuration for the (ZeroMQ based) API.
[concentratord.api]
# Event PUB socket bind.
event_bind="ipc:///tmp/concentratord_event"
# Command REP socket bind.
command_bind="ipc:///tmp/concentratord_command"
# LoRa gateway configuration.
[gateway]
# Antenna gain (dB).
antenna_gain=0
# Public LoRaWAN network.
lorawan_public=true
# Region.
# The region of the gateway. Options:
# EU868, US915, CN779, EU433, AU915, CN470, AS923, AS923_2, AS923_3, AS923_4,
# KR923, IN865, RU864
# Not not all the gateway models implement all regions.
region="EU868"
# Gateway vendor / model.
# This configures various vendor and model specific settings like the min / max
# frequency, TX gain table.
model="sandbox_lorago_port"
# Gateway vendor / model flags.
model_flags=[]
# Gateway ID.
gateway_id="b827ebfffe31f94b"
# Reset pin.
# Note: most model configurations come with a pre-defined reset_pin, in which
# case the setting below will be ignored.
reset_pin=0
- Note the
log_to_syslog=false change!
Then to start by hand:
chirpstack-concentratord-sx1301 -c concentratord.toml -c region.toml -c channels.toml
root@ChirpStack:/var/etc/chirpstack-concentratord# chirpstack-concentratord-sx1301 -c concentratord.toml -c region.toml -c channels.toml
2023-08-02T13:08:59.035Z INFO [libconcentratord::reset] Configuring reset pin, dev: /dev/gpiochip0, pin: 25
2023-08-02T13:08:59.036Z INFO [chirpstack_concentratord_sx1301::cmd::root] Starting Concentratord SX1301 (version: 4.2.0, docs: https://www.chirpstack.io/concentratord/)
2023-08-02T13:08:59.036Z INFO [libconcentratord::reset] Triggering sx1302 reset
2023-08-02T13:08:59.236Z INFO [chirpstack_concentratord_sx1301::concentrator] Setting spi device path, spidev_path: /dev/spidev0.0
2023-08-02T13:08:59.236Z INFO [chirpstack_concentratord_sx1301::concentrator] Setting board configuration, lorawan_public: true, clock_source: 1
2023-08-02T13:08:59.236Z INFO [chirpstack_concentratord_sx1301::concentrator] Setting up concentrator radios
2023-08-02T13:08:59.236Z INFO [chirpstack_concentratord_sx1301::concentrator] Configuring radio, radio: 0, enabled: true, center_freq: 867500000, type: SX1257
2023-08-02T13:08:59.236Z INFO [chirpstack_concentratord_sx1301::concentrator] Configuring radio, radio: 1, enabled: true, center_freq: 868500000, type: SX1257
2023-08-02T13:08:59.236Z INFO [chirpstack_concentratord_sx1301::concentrator] Setting up concentrator channels
2023-08-02T13:08:59.236Z INFO [chirpstack_concentratord_sx1301::concentrator] Configuring multi-SF LoRa channel, channel: 0, enabled: true, freq: 868100000, rf_chain: 1, if_freq: -400000
2023-08-02T13:08:59.237Z INFO [chirpstack_concentratord_sx1301::concentrator] Configuring multi-SF LoRa channel, channel: 1, enabled: true, freq: 868300000, rf_chain: 1, if_freq: -200000
2023-08-02T13:08:59.237Z INFO [chirpstack_concentratord_sx1301::concentrator] Configuring multi-SF LoRa channel, channel: 2, enabled: true, freq: 868500000, rf_chain: 1, if_freq: 0
2023-08-02T13:08:59.237Z INFO [chirpstack_concentratord_sx1301::concentrator] Configuring multi-SF LoRa channel, channel: 3, enabled: true, freq: 867100000, rf_chain: 0, if_freq: -400000
2023-08-02T13:08:59.237Z INFO [chirpstack_concentratord_sx1301::concentrator] Configuring multi-SF LoRa channel, channel: 4, enabled: true, freq: 867300000, rf_chain: 0, if_freq: -200000
2023-08-02T13:08:59.237Z INFO [chirpstack_concentratord_sx1301::concentrator] Configuring multi-SF LoRa channel, channel: 5, enabled: true, freq: 867500000, rf_chain: 0, if_freq: 0
2023-08-02T13:08:59.237Z INFO [chirpstack_concentratord_sx1301::concentrator] Configuring multi-SF LoRa channel, channel: 6, enabled: true, freq: 867700000, rf_chain: 0, if_freq: 200000
2023-08-02T13:08:59.237Z INFO [chirpstack_concentratord_sx1301::concentrator] Configuring multi-SF LoRa channel, channel: 7, enabled: true, freq: 867900000, rf_chain: 0, if_freq: 400000
2023-08-02T13:08:59.237Z INFO [chirpstack_concentratord_sx1301::concentrator] Configuring Std LoRa channel, enabled: true, freq: 868300000, rf_chain: 1, if_freq: -200000
2023-08-02T13:08:59.237Z INFO [chirpstack_concentratord_sx1301::concentrator] Configuring FSK channel, enabled: true, freq: 868800000, rf_chain: 1, if_freq: 300000
2023-08-02T13:08:59.237Z INFO [chirpstack_concentratord_sx1301::concentrator] Starting the concentrator
2023-08-02T13:09:02.397Z INFO [libconcentratord::events] Creating socket for publishing events, bind: ipc:///tmp/concentratord_event
2023-08-02T13:09:02.398Z INFO [libconcentratord::commands] Creating socket for receiving commands, bind: ipc:///tmp/concentratord_command
2023-08-02T13:09:02.398Z INFO [libconcentratord::jitqueue] Initializing JIT queue, capacity: 32
2023-08-02T13:09:14.303Z INFO [chirpstack_concentratord_sx1301::handler::uplink] Frame received, uplink_id: 1876312863, count_us: 14548099, freq: 868100000, bw: 125000, mod: LoRa, dr: SF7
