v4.3.0
Upgrade notes
This release updates the PostgreSQL database version. If you would like to retain all data, You must create a PostgreSQL + Redis backup before upgrading. You must use the following commands (using SSH):
mkdir -p /srv/backup
chmod 777 /srv/backup
sudo -u postgres /usr/bin/pg_dump -h localhost -d chirpstack -F c -f /srv/backup/chirpstack.pg
service redis stop
cp /srv/redis/dump.rdb /srv/backup/chirpstack.redis
service redis start
After upgrading, you can use the Restore ChirpStack backup command to restore the backup. For future backups, you can use the Create ChirpStack Backup command (see features) after upgrading.
Features
PostgreSQL & Redis backup / restore
This adds Create ChirpStack backup and Restore ChirpStack backup commands under System > Custom Commands.
Other features
- Add Wireguard VPN support.
- Add experimental support for RAK7268v2 gateways (to be documented).
Updates
- Update OpenWrt to v23.05.2.
- Update ChirpStack to v4.6.0.
- Update ChirpStack Concentratord to v4.3.5.
- Update ChirpStack MQTT Forwarder to v4.1.3.
- Update ChirpStack UDP Forwarder to v4.1.6.
