ChirpStack Network Server v3.12.0-test.1
Features
Private gateways
This adds the option to add a service-profile to a gateway and a service-profile
flag to make all gateways under that service-profile private. It also adds a
global configuration option to make all gateways private. When a gateway is
private, only devices under the same service-profile will be able to use the
gateway.
Improvements
- Implement uplink frame counter for Prometheus. (#507)
Testing
Debian
Use the testing channel instead of stable:
sudo echo "deb https://artifacts.chirpstack.io/packages/3.x/deb testing main" | sudo tee /etc/apt/sources.list.d/chirpstack.list
Docker
Use the chirpstack/chirpstack-network-server:3.12.0-test.1 image and tag.
