[release] ChirpStack Network Server v3.15 test releases
v3.15.0-test.1
Features
Gateway metrics
This implements the forwarding of the additional gateway metrics implemented by ChirpStack Gateway Bridge v3.13.0 to the ChirpStack Application Server.
Improvements
  • Add AS923_4 band (AS923 with -5.90 MHz frequency offset).
Bugfixes
  • Remove sending mac-commands in Class-C downlink. (#543)
  • Fix AS923 sub-bands (_2 and _3) in GetVersion API response.
Testing
Debian
Use the testing channel instead of stable:
sudo echo "deb https://artifacts.chirpstack.io/packages/3.x/deb testing main" | sudo tee /etc/apt/sources.list.d/chirpstack.list
Docker
Use the chirpstack/chirpstack-network-server:3.15.0-test.1 image and tag.
