This implements the forwarding of the additional gateway metrics implemented by ChirpStack Gateway Bridge v3.13.0 to the ChirpStack Application Server.
Improvements
Add AS923_4 band (AS923 with -5.90 MHz frequency offset).
Docker images added for ARM v6, v7 and ARM64. (#546)
Bugfixes
Remove sending mac-commands in Class-C downlink. (#543)
Fix AS923 sub-bands (_2 and _3) in GetVersion API response.
Allow receiving less tx acknowledgements than downlink items sent to the gateway. E.g. two items were sent to the gateway, responded by a single OK acknowledgement (indicating the first item was sent).
@brocaar I installed chirpstack v3.15 in raspberry, but when I use AS923_4, some wrong accurred as follow:
pi@gateway:~ $ chirpstack-network-server version
WARN[0000] No configuration file found, using defaults. See: Configuration - ChirpStack open-source LoRaWAN<sup>®</sup> Network Server
3.15.1
pi@gateway:~ $ sudo /usr/bin/chirpstack-network-server FATA[0000] setup band error: get band config error: lorawan/band: band AS923_4 is undefined
I used the default configure file with only band changed. please give some help, thank you in advance.
I’m looking at frame logging feature introduced in v3.14 - lowering the per_device_frame_log_max_history to 5 returns last 5 frames on LORAWAN FRAMES device tab as expected, but DEVICE DATA tab still shows last 10 messages. Bug or feature?
EDIT: Nevermind, found per_device_event_log_max_history under app-server config, which I guess will do the trick.
