v3.16.1
Features
- Add LR-FHSS ADR algorithms (LoRa + LR-FHSS and LR-FHSS only).
- Add dev-nonce clear functionality. (#570)
Improvements
- Log fNS downlink frames for gateway. (#569)
- Run packet-handlers as goroutines. (#564)
Bugfixes
- Configure roaming
Authorization header for default client. (#573)
- Return
UnknownDevAddr and MICFailed errors in roaming. (#574)
v3.16.2
Bugfixes
- Fix concurrent handling in case of ghost OTAA packets.
- Fix missing gateway meta-data cache flush.
v3.16.3
Improvements
- Update mqtt client dependency.
- Update to Go 1.18.
Bugfixes
- Add
db to joinContext. (#590)
- Fix NewChannelReq for LoRaWAN 2.4 gHz. (#65)
brocaar
4
v3.16.4
Improvements
- Send also ack errors from mac-only messages to AS. (#596)
- Cleanup DevEUI from DevAddr → DevEUI set, if device-session does not exist.
v3.16.5
Improvements
- Update build to latest Go toolchain.
brocaar
6
v3.16.6
Improvements
- Update Go compiler to v1.19.3.
- Update Alpine base container to v3.17.0.
- Update prometheus/client_golang to v1.14.0.
