ChirpStack Network Server v3.7.0-test.1
Features
Improve frame-counter validation
The refactored frame-counter validation makes it possible to report different types of errors to the Application Server which will make it easier to debug frame-counter related issues.
OTAA error event
OTAA related errors will now be pushed to the Application Server to make it easier to debug OTAA related issues.
Downlink tx acknowledgements
Downlink TX acknowledgements (by the gateway) are now forwarded to the Application Server. Please note that this is the TX acknowledgement by the gateway, indicating that it was enqueued for transmission.
Syslog output
When log_to_syslog
is enabled in the configuration file, the log output will be written to syslog.
Improvements
- Implement setting max reconnect interval for MQTT gateway backend.
- Implement getting the device queue size only (instead of fetching the complete queue).
- Implement DNS round-robin load-balancing for gRPC.
- Cleanup old
api
package (the API definitions have been moved to chirpstack-api). - Add uplink IDs to geolocation events for correlation.
- Remove legacy (and broken) device-session migration code.
- Cleanup (unused) gateway statistics code.
Testing
Debian
Use the testing
channel instead of stable
sudo echo "deb https://artifacts.chirpstack.io/packages/3.x/deb testing main" | sudo tee /etc/apt/sources.list.d/chirpstack.list
Docker
Use the chirpstack/chirpstack-network-server:3.7.0-test.1
image and tag.
