v4.1.0
Features
API request logging
This feature logs API requests to Redis Streams. This enables external services to monitor for example device create, update and deletes by reading from the Redis Streams. A code-example can be found here.
Uplink logging for unknown devices
While the feature to log frames was already present, it was not possible to only read uplink frames of devices that are unknown. This extends the frame logging feature to also log uplinks for unknown devices, in which case DevEUI 0000000000000000 is used. A code-example for reading the frame log can be found here.
Event logging
A code-example to read event logs from the Redis Streams was added. It can be found here.
Improvements
- Make
metadatafields in gateway messages consistent. - Emit all fields for JSON integration messages, even if they are their default values. (#63)
Bugfixes
- Fix Redis pipelined commands in case Redis Cluster is configured.
- Fix UI notifications z-index.
Other changes
- The
import-ttn-lorawan-devicessub-command has been renamed toimport-legacy-lorawan-devices-repository.
