This release refactors the uplink de-duplication, such that uplinks received by gateways in different region configurations (but with overlapping channels) are de-duplicated separately. After de-duplication and after resolving the device-session of the device, ChirpStack will only handle the de-duplicated uplink that is within the same region-configuration assigned to the device-session.
This makes it possible to create region configurations of which channels and gateway-coverage are overlapping. Before this release such scenario could result in constantly changing settings (through mac-commands) of the end-device or errors related to unknown channels.
This does include two integration changes:
Region information is no longer exposed through the rxInfo elements.
A new region_config_id field has been added to join and uplink events.
I have been focused on other areas of my service and am still running ChirpStack 4.7. Can I go directly to 4.11 or is it recommended to upgrade to 4.8, 4.9, etc. to get to 4.11?
While it is always good to “dry-run” an upgrade on a test environment (and to make backups), you should be able to upgrade from v4.7 to v4.11.0 directly. ChirpStack keeps track of the database migrations, and on start will apply what hasn’t applied yet (all database migrations are embedded inside the binary).
Need your help here brocaar, I 'm very new to linux or chirpstack its a blocker for us to move further.
And also suggest a procedure to install specfic version of chirpstack lets say V4.9.0, but when we follow chirpstack documentation "sudo echo “deb Index of /packages/4.x/deb/ stable main” | sudo tee /etc/apt/sources.list.d/chirpstack.list
" .It redirrects us to get latest version of chirpstack.
the ns_time explains why i was missing some uplinks from an lns upgraded to v4.11.0
I have another problem which may just be a me/python problem, but I use pydantic on the uplink messages to a fastapi endpoint and i have been getting a few UUID4 validation errors on the deduplicationId from uplink messages. this is an example of one failing the pydantic UUID4 test db72be85-1c44-63c4-db72-be851c4463c4 i checked with a few online validators and they also seemed to be 50/50 on saying it was a valid UUID4.
for the time being I have just replaced the check with inbuilt python uuid check which seems to see them as valid, I have not checked this inbuilt library it may just be a regex check on the string
